  4. Possible bug in route calculation
8 Posts 4 Posters 3.3k Views 2 Watching
  • cvlmtg
    cvlmtg
    cvlmtg
    I have a route which I want to convert from tomtom to here, but it says it cannot calculate a part of the route. It seems strange as 1) I can reach a waypoint but somehow I cannot go back and 2) if it's not that waypoint the problem, there are plenty of alternative routes in case one road is closed.
    I also checked with google maps and there seems to be no problem reaching and leaving that waypoing, so I suspect there might be a bug in the HERE maps.
    the route is here:
    https://www.myrouteapp.com/en/social/route/8034705?mode=share
    • cvlmtg cvlmtg
      the route is here:
      @cvlmtg It is not a bug at al! Firstly, waypoint 2 is not on the road but outside of it. Make sure to place all your waypoints directly on the road surface. If you move waypoint 2 a bit more in the direction of the main road, the route will work. Is it intended for you to deviate from the main road at the location of waypoint 2? If not, then place your waypoint exactly on Via Enzo.
      I would also recommend placing more than 3 waypoints. If the intention is to follow that exact route, having so few points increases the likelihood of being presented with a different route along the way. Adding multiple via points and/or shaping points at strategic locations will indeed ensure that the route is followed as you intend.
      cvlmtg 1 Reply Last reply
        Something is wrong with WP 2.
        Place it at the beginning of this hill.
          cvlmtg
          cvlmtg
          cvlmtg
          @Rob-Verhoeff said in Possible bug in route calculation:
          I see that, but it confuses me a bit, because if I press "help me solve this" the route from point 1 to 2 is calculated correctly, but not from point 2 to 3, so point 2 position didn't seem to be the cause.
          The "real" route is another one, this is a copy I created with just the minimum points needed to replicate the problem.
          Thanks!
            cvlmtg
            cvlmtg
            cvlmtg
            @Jörgen said in Possible bug in route calculation:
            Thanks!
            • cvlmtg cvlmtg
              Thanks!
              @cvlmtg Is your intention to drive up that road to waypoint 2? If not, move it to the mainroad and problem is solved?
              • Hathi
                Hathi
                Hathi
                I have the same problems with route i made week ago and then he did calculate. Now on reopening he does not even an all my older routes ( years ago) now he van not calculate even if points are close to each other. Hope it is soon solved
                • Hathi Hathi
                  @Hathi share your route and we can look into it.
                  cvlmtg
                  cvlmtg
                  Hathi
                  Hathi
                  • Online map settings
                    MartinW
                    MartinW
                  • Real-time traffic
                    Òscar
                    Òscar
                    Andy Nicholson
                    Andy Nicholson
                  • HERE map not calibrated
                    MartinW
                    MartinW
                  • Myrouteappstay
                    Bé Jeuring
                    Bé Jeuring
                  • Navigatie met DMD tablet
                  • Show on the maps's button
