  3. PDF format
PDF format
6 Posts 4 Posters 848 Views
  • Mike 56undefined Offline
    Mike 56
    I am looking for help on changes that happened to my routes.
    I have mapped out several rotes and was able to save them and export them to my GPS and they worked fine. I saved a Tracking log as a pdf to try to print is , now all of my routes have been changed to pdf format and any new routes I make and try to save or export as a gpx are all converted to pdf.
    Anybody know how to correct this?
    Any suggestions will be greatly appreciated.
    RetiredWingManundefined Hans Kremersundefined Albert van den Elsenundefined 3 Replies Last reply
    • Mike 56undefined Mike 56
      @Mike-56 can you provide a little more detail about the process you are using:
      1. How do you create the routes?
      2. What do you mean by save them?
      3. What steps do you go through to export the routes?
        Mike 56
        Hi Doug, I just put a route into my Goldwing gps, it loaded fine and seems to be working. I plan out the route in the MyRoute-app and save it. When I was selecting it and exporting it as a gpx file the icon shows it to be a pdf file. It had me confused for a minute so I loaded the file on to the sd card and it uploaded into the gps and seems to work just fine. I am fairly new to this app but from what I have seen so far I think I am going to sign up for the lifetime Gold and Navigation.. I want to try a few more things first though.
        Thanks for reaching out to help, much appreciated.
        Mike
          Mike
          @Mike-56 I'm sure you will enjoy the app. Be safe out there.
            Hans Kremersundefined Offline
            Hans Kremers
            @Mike-56
            I'm not sure about this, but to me it sounds as if the OS setting for default application to open GPX files with has been set to your PDF reader. This would cause the OS to show a PDF icon for your GPX files.
            You might want to check in your OS what the default handler for GPX files is.
              Albert van den Elsenundefined Offline
              @Mike-56 Hans Kremers is correct.
              This is a file editing setting of the operating system and has nothing to do with MRA.
              It means that the operating system (e.g. Windows) has not recognized the file extension GPX as a known file extension. In this case, the operating system asks you how to deal with the GPX extension. You may have told the operating system to treat it as a PDF extension. In windows you can always change this under the file type settings.
              iPhone 15,
              Carpe Iter Tablet V4C
              Sena 20S EVO headset
              Harley Davidson Road King 2017 M8.
              Mike 56undefined
              Mike 56
              Hans Kremers
              • Update 5.0.3 - Device management
                Cleoundefined
                Cleo
                1.7k
                1.6k
              • Siri gebruiken met CarPlay
              • I am starting to hate this app right about now ...
                Cleoundefined
                Cleo
              • Snelheidsweergave in spit screen modus carplay
              • In eens verdwenen mogelijkheid om 3 apparaten te gebruiken als Gold member?
                Bouke Entundefined
              • Web symbol on my Android phone
                Terence Rawcliffe 0undefined
                Terence Rawcliffe 0
