  4. Nav 6 not showing tracks
8 Posts 4 Posters 2.2k Views 2 Watching
  • Mark sadz
    Mark sadz
    Mark sadz
    Hi folks just got a bmw nav 6 (brand new) when I export a route the track isn't exporting only the trip. Any ideas why this is happening?
    Cheers
    TorqueRider Rob Verhoeff Hubert Thoring 3 Replies Last reply
    • Mark sadz Mark sadz
      Cheers
      @Mark-sadz
      That's correct. The export function only places the route on your device.
        Cheers
        @Mark-sadz you should export it as a .gpx 1.1 (route, track, POI).
        đźš™ Apple CarPlay in VW T-Roc
        đź’» Routelab on MacBook Air & iMac (Golden Gate & Ventura)
          @Rob-Verhoeff
          Isn't that the "Save as" option?
          TS is mentioning to export a route.
          • TorqueRider TorqueRider
            @Rob-Verhoeff
            @Jack-van-Tilburg the export tool works fine for me. But I have a Nav V. I don’t know if the Nav VI is mounted on a fixed position. Than Save as gpx 1.1.
            What’s in a word “save as” or “export”. In both way's the route has to go to a different spot. But you are right. The menu say's save as.
              @Rob-Verhoeff
              I sold my last Garmin last week. And can therefore no longer simulate it with a device.
              I do see that the export places a track and a route in the GPX map. But I don't know how it works on the device.
              @Mark-sadz
              TS will have to provide a little more explanation about the way it worked during and after export.
              Particularly because three indications are given; Track, route and trip? What does TS mean by trip?
              Mark sadz 1 Reply Last reply
                @Rob-Verhoeff
                @Mark-sadz
                Mark sadz
                Mark sadz
                Mark sadz
                @Jack-van-Tilburg I've found a work around. save as and then upload to basecamp. I can then load the track onto the nav 6 via basecamp. Every route I export (in whatever format) from MRA only saves it as a trip on the nav 6.
                  Cheers
                  @Mark-sadz Hey das hilft dir bestimmt!!đź‘‹
                  BMW Navi N6 - Route als GPX 1.1 laden
                  Mark sadz
                  Mark sadz
                    MartinW
                    MartinW
                    MartinW
                    MartinW
                  • BĂ©ta to no-bĂ©ta
