  4. Android Auto - Night mode always on
11 Posts 5 Posters 135 Views 1 Watching
  • ATLastundefined Offline
    ATLast
    Hi.
    I launch MyRoute on the phone, map is in day mode. I connect to Android Auto, map switches to night mode.
    I launch MyRoute on Android Auto, map always on night mode...
    • ATLastundefined ATLast
      Hi.
      Jack van Tilburg
      @ATLast
      Android Auto en Apple CarPlay are still "under construction".
      ATLastundefined 1 Reply Last reply
        @ATLast
        ATLast
        @Jack-van-Tilburg I know, but as this is a place to report bugs, I post them...
          M. Schrijverundefined Offline
          Better late than never.
          I've noticed this also with other apps. It seems an AA thing not a MRA specific thing.
            @M-Schrijver and I think it depends on the brand AA because mine starts up in daylight mode
              @Marinus-van-Deudekom
              First time (mostly in the morning) nearly everytime it starts in night/dark mode. Other times during the same day it is the correct mode.
              If available, the light sensor in AA Headunit should determine if night- or -daymode is required. Otherwise it should be the phone.
              Con Hennekensundefined Marinus van Deudekomundefined 2 Replies Last reply
                @M-Schrijver, I have seen similar behaviour only on GMaps 🤣
                Suddenly during bright daylight and no tunnels in sight it often changes to darkmode, sometime for hours. And then it suddenly changes back...
                  @M-Schrijver I've had both the phone and Android Auto on at the same time. Whenever I hit a tunnel both devices change mode at exactly the same time. That makes me believe it's the mode of the phone leading the way.
                  Today I used only Android Auto and when I hit a tunnel Android Auto changed mode so now I'm not shure anymore.
                  Maybe @Corjan-Meijerink can share his opinion on this. I bet he knows 🙂
                    The sensors of the AA headunit has the highest priority. The sensor of the phone comes next.
                    In my case (Goldwing 2018) everything is done by the Goldwing headunit because it has al the required sensors. The phone is only the source of the software and does the calculations.
                      @M-Schrijver said in Android Auto - Night mode always on:
                      The MRA app does not use the phones light sensor at all. It uses knowledge in the map concerning tunnels and sunset/dawn information (most likely from the GPS signal).
                        MRA has three settings
                        Auto
                        Light
                        Dark.
                        "Light" and "Dark" are manual settings.
                        "Auto" is determined by the OS of your phone. In case of AA is it AA which determined with i.e the light sensor which theme (light of dark) is used.
                        so, MRA must provied the posibilty but the phone makes the choice
                        ATLastundefined
                        ATLast
                        Jack van Tilburg
                        • Routepunten
                          Arie Boerundefined
                          Arie Boer
                        • Sealevel
                          RideToPortugal.comundefined
                          RideToPortugal.com
                        • Expand
                          Martin Woodfordundefined
                          Martin Woodford
                        • Account blocking issue
                          b0hd1undefined
                          Jon Hye-Knudsenundefined
                          Jon Hye-Knudsen
                          1.8k
                        • Tracklog fails
