  4. Instruction at roundabout
3 Posts 3 Posters 63 Views 2 Watching
  • Ian Batterham
    Ian Batterham
    Ian Batterham
    During a journey (130+ miles) to Durham (UK) travelling along A690 westbound from A1(M) into Durham there are a number of roundabouts. At each one the instruction was "turn left" when the display showed to take either the 2nd or 3rd exit. The normal instruction to "take 2nd exit" was not given. At all other times the correct instructions were given.
    Dikke Wim 1 Reply Last reply
    • Ian Batterham Ian Batterham
      Dikke Wim
      Dikke Wim
      Dikke Wim
      @Ian-Batterham
      I'm not sure this is a problem with Navigation Next. Most probably this is a problem with the HERE/Garmin map.
      • Rob Verhoeff
        @Ian-Batterham This can also occur if you have placed a shapingpoint or a viapoint just before the particular roundabout. I'm not sure if that applies to your route. If it does, try placing the waypoint after the roundabout.
        Dikke Wim
        Dikke Wim
        Ian Batterham
        Ian Batterham
          Axel Lange
          Axel Lange
        • In het kort......
        • Route probleem
          Jack 13
          Jack 13
