  4. Performance when tracking
10 Posts 6 Posters 156 Views 1 Watching
  • RetiredWingMan Online
    Over the past couple of days I was on a group ride as a member. I turned on tracking. Battery usage was much lower and I could run all day without charging. The tracking also kept up and was quite accurate. I found the OSM overlay to provide the best information. The Tomtom was fairly good as well. Perhaps not having to deal with the Here maps is what reduced battery usage.
      Corjan Meijerink Offline
      @Doug-Robinson When not navigating at all - the app is pretty battery efficient šŸ™‚
      Most battery usage is caused by drawing the HERE map while navigating.
      • richtea999 Offline
        richtea999 Offline
        @Corjan-Meijerink Ah! So a 2D birdseye view built with tiled maps (rotated according to the users heading), and overlaid with just current position and travelled track might save a lot of battery?
        Some users might appreciate that option if it was available.
        • richtea999 richtea999
          Rob Verhoeff Offline
          @richtea999 if you mean a kind of ā€œfreedriveā€ mode with upcoming streetinfo etc. then that suggestion is already been noted. I guess that this feature has no priority right now.
            richtea999 Offline
            @Rob-Verhoeff said in Performance when tracking:
            Ah, no. I should have been more accurate: '2D tiled maps overlaid with future route, current position and travelled track'. In other words I was suggesting a simpler way of rendering the live route map. If you use tiled areas of maps (prefetched, since you know where the route is going) then the processing power may be less than drawing the current pseudo-3D vector views, which I suspect are heavy on processing power. 'Tiling' is what most games would use and it's heavily optimised for speed and power in mobile APIs. Just a thought, but probably quite tricky for MRA to offer as an option to the current 3D view.
            Lynchy67 1 Reply Last reply
              Lynchy67 Offline
              Lynchy67 Offline
              @richtea999
              I have been trying out some simplified options for when I ride alone.
              I like the simplicity of the examples below.
              All screenshots are from a route recorded last weekend.
              Snapshot 04-07-2023 12:23.jpeg Snapshot 04-07-2023 12:23.jpeg Snapshot 04-07-2023 12:24.jpeg Snapshot 04-07-2023 12:24.jpeg Snapshot 04-07-2023 12:25.jpeg Snapshot 04-07-2023 12:26.jpeg
              • Lynchy67 Lynchy67
                @richtea999
                @Lynchy67 I prefer to see the name and route # of the upcoming turn. I would prefer not to see upcoming waypoints in place of the next navigation instruction. In your first example, waypoint 9 is hiding the upcoming right turn.
                  @richtea999, these scenarios have all been testet, and however unthinkable, it all made no difference... Even lowering the frequency did not change anything substantial. It's the drawing engine consuming the energy, no matter what gets drawn... HERE is stepping in for assistance, but they are not as quick like we are used to from the MRA dev team šŸ˜‰
                    Lynchy67 Offline
                    Lynchy67 Offline
                    @Doug-Robinson
                    Yes I agree waypoint 9 was a bad choice to make.
                    Still getting my head around the best way to get just the turn notifications and no Waypoints visible.
                      richtea999 Offline
                      @Lynchy67 said in Performance when tracking:
                      @Doug-Robinson
                      Put the waypoint just after the turn - then you'll see the turn notification first and the waypoint notification second.
                      • Welke instelling
                        1.1k
                      • The slow death of Zumo...
                      • opslaan naar plantomtom
                        chris 18
                        chris 18
                      • Rejoining routes
                      • Seizoen sluitingen wegen
                        PAT62
                        PAT62
                        Thomas SchƤfer
                        Thomas SchƤfer
                        Terry Cox 0
                        Terry Cox 0
                        Karl-Heinz Schwendner
