  3. Suggestion: When converting track, make it possible to let it be a cycle route
2 Posts 2 Posters 518 Views 1 Watching
  • reinier.beenengmail.com
    When converting a track to a route, I reguarly want to create a bicycle route. However, MRA converts it always to a route for motorways. Afterwards you can change this to a cycle-route, but then you have to move all route points to cycle roads. It so much less time consuming when MRA already puts the generated route points on cycle roads.
    The functionality is already there because when I create a new route from the menu, I can set the driving mode to cycle.
    So the suggestion is to create the possibility to generate a cycle-route based upon a routetrack (which off course is already a cycle-track)
    • Rob Verhoeff
      @Reinier007 The map used for navigation is the Here map. When designing bike routes, it's better to immediately make use of the OSM map. You can convert the routetrack, but then you have to switch to the OSM-map and check al waypoints for there exact position on the road. Although you won't have turn-by-turn navigation when cycling, it's very easy to follow the line. All your shaping and via points will also be displayed. Apparently, the Here map is suitable for turn-by-turn navigation while cycling in some countries, but that's not the case for the Netherlands.
      šŸ’» Routelab on MacBook Air & iMac (Golden Gate & Ventura)
      • Map lock
        tfdahazellgmail.com
        tfdahazellgmail.com
      • Beta abonnement
        BMW1300GSA
        BMW1300GSA
        2.3k
        Gerard van der Veer
        Gerard van der Veer
      • Uitnodiging
        Hanza 0
        Hanza 0
        Hans Kremers
        Hans Kremers
      • SilverFox Controller C2
        Hans Lamers
        Hans Lamers
