  3. How do I close a route from a friend to make a circular route?
11 Posts 4 Posters 457 Views 1 Watching
  • Steve Crowtherundefined Offline
    Steve Crowther
    I want to close the route so it begins and ends at the same place.
    How do I add the route from WP1 to WP45?
    • Paul Jennerundefined Offline
      Paul Jenner
      You can drag #45 to very close to #1.
      Then add points along that new part of the route to adjust which roads you want to take.
      Paul.
        Paul Jenner
        Oh, and it is necessary to first add a point to slightly south to the current #45. #45 will then automatically turn into # 46, then drag the new #46 to close in on #1, rest as above,
        Paul.
        • Steve Crowtherundefined Steve Crowther
          Rob Verhoeffundefined Offline
          @Steve-Crowther, you can directly add a new waypoint to your route on a road you want to drive on. That waypoint will automatically be labeled as #46. Add as many waypoints as necessary for you to complete the route.
          It is not necessary to first add an extra point to the existing route and then move the new point #46 to a road you wish to drive on.
            Steve Crowther
            Excellent, thanks, that seems to work, but it's a shame it can't be asked to plot a route between two existing waypoints.
            I'm changing from Basecamp which allows you to plot between two existing waypoints, I assume that every route I plot now needs a new "Start" from my home to a new "Finish" to my home?
            Rob Verhoeffundefined Paul Jennerundefined 3 Replies Last reply
              @Steve-Crowther No, you can place a new waypoint between two points also. Move the hand over the routline and wait until it changes in the "shapingpoint" with the + inside. Then click on the line and a new waypoint is placed between two existing shapingpoints.
                Paul Jenner
                @Steve-Crowther said in How do I close a route from a friend to make a circular route?: .....but it's a shame it can't be asked to plot a route between two existing waypoints.
                MRA does plot a route if you follow my method.
                Paul.
                  I don't really understand what you mean with this. You actually can plot between two existing waypoints. If you place a point in the proximity of point #1 that point wiill automaticly be numbered as #46 and you route will be complete. After that you can pick-up the routeline between points #45 and #46 and drag it to the roads you want to drive on.
                  Steve Crowtherundefined 1 Reply Last reply
                    Steve Crowther
                    @Rob-Verhoeff I think it's the different concept or something. With Basecamp I could choose WP1 as the final end to the route without having to add WP46 so the route would be from WP1 through all the WPs back to WP1
                    It's not a problem as I've just used your method, different way of doing it is all.
                    Unless I'm wrong, and I could well be since I've just started using MRA, the WPs as are not saved to be used in new routes, and you cannot click on current WP's on the route to include them two or three times.
                    I did have WPs in Basecamp at strategic junctions etc. so used them in more than one route and more than once in a route,
                    Con Hennekensundefined Rob Verhoeffundefined 2 Replies Last reply
                      @Steve-Crowther, That is called POI's not Waypoints. Waypoints are route specific. POI's can be used in multiple routes.
                        That is not possible in MRA. #1 is start and #x is finish of end...
                        Steve Crowther
                        Paul Jenner
                        • Waypoint / Viapoint Icons
                          Lex.Kloet.RXundefined
                          Lex.Kloet.RX
                        • Tracklog omzetten naar route geeft veel verschillen
                          Jan Weerheimundefined
                          Jan Weerheim
                        • MRA is only speaking with French accent??
                        • different results with different phones!
                          D Griffinundefined
                          D Griffin
                        • Zoom functies
                        • Route als track hoe werkt dit nu?
                          Bouke Entundefined
                          1.6k
                        • Waypoints (Again!)
                        • Implement 2FA for login
                          Rainer Treichelundefined
                          Rainer Treichel
