  4. Parametre de zoom pour la carte et les indications
14 Posts 4 Posters 84 Views 1 Watching
  • Calibos Calibos
    What I wanted to say is to add two customizable parameters that will be general to the whole application.
    1-A map zoom value parameter set to a value chosen by the user. We will of course keep the possibility of zooming directly with the +/- keys as is already the case but this will avoid having to zoom to each time a route is loaded and in addition if subsequently the developer implements an automatic zoom at intersections, the return to the default zoom will be found
    2- An independent text zoom parameter but always set to a value chosen by the user
    I tested the app with a phone this morning and I better understand why my suggestions are more difficult to understand with a smaller screen.
    But isn't the possibility of adapting an app to all users the problem permanent and so complex of each developer ?
    @Calibos Yes, completely clear now.
    Having a default setting in your personal preferences to set a zoom level so that you don't have to adjust it constantly is understandable and can be handy.
    I don't think scalable texts will be implemented for now. This means that all text-containing boxes should also be variable. It is not on the roadmap and I'm afraid it won't be added for the time being.
    • Calibos
      Calibos
      Calibos
      I can easily understand that all these suggestions represent a considerable amount of work being myself an industrial application designer. You just have to put these "good ideas" in a list for later.
      • Calibos Calibos
        @Calibos said in Parametre de zoom pour la carte et les indications:
        I understand your point, but like you, I'm just an ordinary user. However, developers do read along.
        • Calibos
          Calibos
          Calibos
          it's also good to debate between app users.
            And I read everything πŸ˜‰
            I've added the suggestion on our community feedback backlog for after the release.
            Calibos 1 Reply Last reply
              Calibos
              Calibos
              Calibos
              thank you and congratulations for all.
              β€œIt is often reported when something is wrong but rarely when it is going well”
              • RetiredWingMan
                I also find the extremely small POI symbols on the maps impossible to read/decipher while riding. The following screen shot is from my tablet which is much larger than my phone.
                  @Doug-Robinson those POI's are comming with the map-provider. I don't think MRA is able to make that better.
                    @Rob-Verhoeff I can zoom in on the map but the POIs remain the same size.
                      @Doug-Robinson yep, also on this side. But when zooming in, more POI's are shown. So I still think it's map-provider dependent.
                        This is something we will look into later πŸ™‚
                        Calibos
                        Calibos
                        • Help please, new user
                          Bull Tahr
                          Bull Tahr
                        • My Routeapp Stays questions
                        • Rijrichting in route
                          4.9k
