  4. Parametre de zoom pour la carte et les indications
14 Posts 4 Posters 84 Views 1 Watching
  • Calibosundefined Calibos
    would it be possible to have a functional zoom parameter for the whole application. (The map and the displays) because on a tablet the basic size is too small in my opinion, with a general functional parameter we could choose a customizable zoom for the entire application.
    Rob Verhoeffundefined Offline
    @Calibos Do you mean on map level or also in texts? The fonts used are not "scalable," which means that if you have selected a larger font size in the settings of your device, MRA doesn't do anything with it. On a map level, you can determine the zoom level yourself when navigating. Click on the +/- sign to do so. When designing the route, you can zoom in as much as you like.
    • Calibosundefined Offline
      Calibos
      What I wanted to say is to add two customizable parameters that will be general to the whole application.
      1-A map zoom value parameter set to a value chosen by the user. We will of course keep the possibility of zooming directly with the +/- keys as is already the case but this will avoid having to zoom to each time a route is loaded and in addition if subsequently the developer implements an automatic zoom at intersections, the return to the default zoom will be found
      2- An independent text zoom parameter but always set to a value chosen by the user
      I tested the app with a phone this morning and I better understand why my suggestions are more difficult to understand with a smaller screen.
      But isn't the possibility of adapting an app to all users the problem permanent and so complex of each developer ?
        @Calibos Yes, completely clear now.
        Having a default setting in your personal preferences to set a zoom level so that you don't have to adjust it constantly is understandable and can be handy.
        I don't think scalable texts will be implemented for now. This means that all text-containing boxes should also be variable. It is not on the roadmap and I'm afraid it won't be added for the time being.
          Calibos
          I can easily understand that all these suggestions represent a considerable amount of work being myself an industrial application designer. You just have to put these "good ideas" in a list for later.
            @Calibos said in Parametre de zoom pour la carte et les indications:
            I understand your point, but like you, I'm just an ordinary user. However, developers do read along.
              Calibos
              it's also good to debate between app users.
                And I read everything πŸ˜‰
                I've added the suggestion on our community feedback backlog for after the release.
                Calibosundefined 1 Reply Last reply
                  Calibos
                  thank you and congratulations for all.
                  β€œIt is often reported when something is wrong but rarely when it is going well”
                    I also find the extremely small POI symbols on the maps impossible to read/decipher while riding. The following screen shot is from my tablet which is much larger than my phone.
                      @Doug-Robinson those POI's are comming with the map-provider. I don't think MRA is able to make that better.
                        @Rob-Verhoeff I can zoom in on the map but the POIs remain the same size.
                          @Doug-Robinson yep, also on this side. But when zooming in, more POI's are shown. So I still think it's map-provider dependent.
                            This is something we will look into later πŸ™‚
                            Calibosundefined
                            Calibos
                              D Griffinundefined
                              D Griffin
                            • MRA V5.0.4 (451) Keine Karte, nur Audio Anweisung
                            • Bevriezen carplay scherm
