  4. Poor map detail
Poor map detail
7 Posts 3 Posters 90 Views
  • Rod Sydenhamundefined Offline
    Rod Sydenham
    Trying to use the app in off line mode. When I load a saved route, there is very little map detail and when I zoom in , the map gets very blurry to the point where it is unreadable.
    I have updated my maps.
    It makes browsing the map virtually impossible.
      Rod Sydenham
      Here is a screen shot
      The only way to get clarity is to go back online. This is very hard on data usage.
      I thought the object of having offline maps and saved routes was to be able to navigate totally offline utilizing routes that were created previously.
      If I am doing something wrong, I would appreciate being steered in the right direction.
      here is how I have the app configured when the maps are very blurry
      • android phone
      • uploaded the route
      • downloaded and updated offline maps
      • navigation is in "offline" mode
      • phone is in "airplane" mode. ie. no data connection
        Result is blurry maps
      • turn the "offline navigation" off - no change
      • turn :airplane mode "off" and the map clears up.
      • Rod Sydenhamundefined Rod Sydenham
        • android phone
        @Rod-Sydenham, I think you may have corrupted map files. Does it come back after clearing data in Android App settings and re-downloading the maps? I have exactly the same map detail working online or offline...
        Rod Sydenhamundefined 1 Reply Last reply
          Rod Sydenham
          I will try the deletion and reloading maps.
          Thanks
            This part of the app doesn’t use the offline maps! The offline maps are only used within the actual navigation 🙂
              Rod Sydenham
              I cleared the cache on the phone, deleted the maps, reloaded the maps, opened an downloaded route, used airplane mode, offline navigation and the route/maps showed up clearly and with detail.
              Thanks for the help
                Thanks for the help
                Rod Sydenham
                @Rod-Sydenham
                example of how map cleared up when the above was done
                Rod Sydenham
                  AWDC LAOundefined
                • Tracklog fails
                  Edwin_Mundefined
                  Edwin_M
                  AWDC LAOundefined
                • Routepunten
                • Is there a trial period for the app?
                • Account blocking issue
