  4. Disable Route Recalculation
suggestion
15 Posts 8 Posters 263 Views 2 Watching
  • Bart 4
    Bart 4
    Bart 4
    Seems to me a good idee, maybe even better then recalculation"off" if color is different with the recalculate part of the route.
      @Matthew-Wiacek Not sure if this will be implemented in all honestly. Will however make sure we discuss it.
      What we do plan to implement is the constant display of the original route. So you can always manually drive back to that line on the map.
      Matthew Wiacek
      Matthew Wiacek
      Matthew Wiacek
      @Corjan-Meijerink said in Disable Route Recalculation:
      That does sound like a great feature. That maybe more useful than the Garmin recalculate on/off option.
        Sjoerd Eggenkamp
        Sjoerd Eggenkamp
        Sjoerd Eggenkamp
        This would be great!
        Small suggestion: could you create a "bullshit button"? Sometimes the devices like this just get it wrong. Or what I want is just to different.
        What I would like: if we start deviating from the route to much I can quickly tell the device: shut-up and do nothing and let me solve it. It should start (or promt to start) once back on the route.
        • lasironayahoo.com
          lasironayahoo.com
          lasironayahoo.com
          Couldn't tell if the thrashing on this subject is done or not, but I think I would like to see something like this done. Last night, I created a simple loop where destination was closer to me than the start point. I just wanted to get familiar with MRA on the road. As it turn out, I rolled past the destination and it constantly wanted me to turn around before I got to the first starting point.
          My use case is that I create many out and back routes. I'm in California and I take quite a few rides up the Pacific Coast, then go east for a while then loop back home. I'm worried that it'll see that crossing a certain freeway is a faster way home instead of sticking to the route/tour I created. There's nothing noting whether a decision on this has been made, so just wanted to chime in.
          iPhone 14 Pro
          • lasironayahoo.com lasironayahoo.com
            @Robert-Lasirona, Thrashing...? The originally calculated routeline will be kept visible (if you tell it to in the settings). That functions a bit according to keeping the track-line visible on a Zumo. Disabling calculations will not happen. And has, as far I am concerned, no use if the usual functions work properly.
            Dikke Wim lasironayahoo.com 2 Replies Last reply
              Dikke Wim
              Dikke Wim
              Dikke Wim
              While navigating with my Nav V (Garmin) I always make the track visible with a black line. The route is pink.
              As soon as I deviate from the route (obstructions, missed a turn, etc.) I still have the original plan visible as a black line. That way it is easy to ride back to the black line and the navigation picks up the route again.
              I would very much appreciate a similar mode in MyRoute, i.e. the original track remans visible at all time.
              • Dikke Wim Dikke Wim
                @Dikke-Wim, That similar mode IS available. That's what I was telling. The original route is kept visible (like your black track line), so you can drive back to the route like you are used to on your Garmin. As an extra (and a plus) you get a suggestion on how to drive back to the route.
                Dikke Wim 1 Reply Last reply
                  Dikke Wim
                  Dikke Wim
                  Dikke Wim
                  Really? You make my day. I didn't have time to test the latest update of Navigation Next beta, but I'm looking forward to test this.
                  Thanks Con! (and the programmers of Navigation Next 👏
                    @Dikke-Wim 🙂 @Con-Hennekens is a great help!
                      lasironayahoo.com
                      lasironayahoo.com
                      lasironayahoo.com
                      @Con-Hennekens said in Disable Route Recalculation:
                      Thrashing...?
                      Sorry, is this inappropriate? I typically use it when ideas are being flushed out and details and aligned between stakeholders.
                      Is this a setting when the route has been started? Because I thought I went thru settings earlier while at my desk and didn't see anything suggesting a way to disable recalculations. I'll look again once I go out for another ride.
                      iPhone 14 Pro
                        Thrashing...?
                        @Robert-Lasirona said in Disable Route Recalculation:
                        No, I just never heard that word in that context 😉
                        No there is no setting to stop calculating. It is the essence of navigation to calculate. But there IS a setting that keeps the original route visible when you deviate. Much like many Garmin users who set their track visible when navigating a route. That gives you the possibility to return to the original route the way you see fit, but it will not stop Next from proposing it's own way back to the route. You may ignore the voice, you know 😉
                        lasironayahoo.com 1 Reply Last reply
                          lasironayahoo.com
                          lasironayahoo.com
                          lasironayahoo.com
                          @Con-Hennekens as it turns out, I just went ahead and edited the route in the HERE map and everything has been running as expect. Also, set it as my default now.
                          iPhone 14 Pro
                          Dikke Wim
                          Dikke Wim
                          Matthew Wiacek
                          Matthew Wiacek
                          Steve Lynch
                          Steve Lynch
                          Bart 4
                          Bart 4
                          lasironayahoo.com
                          lasironayahoo.com
                          Sjoerd Eggenkamp
                          Sjoerd Eggenkamp
                          • Animation
                          • Help please, new user
                            Bull Tahr
                            Bull Tahr
                          • Route line transparency
