  2. Routes & Tracks
  3. Filter in MyRoute-app Library not working correct?
3 Posts 2 Posters 1.1k Views 1 Watching
  • Edwin_M
    Edwin_M
    Edwin_M
    Was looking for some inspiration and looking for some routes in Belgium.
    I noticed that the rating filter is not working correct or I simply do not understand.
    Without a rating filter this route is show. But if set a filter on 3 stars over above it is not shown.
    When going to one of the routes that were result with rating filter. The route is shown as a nearby route below the details of the route
    • Edwin_M Edwin_M
      @Edwin_M
      If I understand you correctly, you say that when filtering with criteria Belgium and three stars, the route "From Nevele exploring to and through the Flemish Ardennes" is not visible.
      I've tried to reproduce that and get that route in the results.
      Could it be that you have applied other filters? Or have I misunderstood your question?
      Edwin_M 1 Reply Last reply
      • TorqueRider TorqueRider
        @Edwin_M
        Edwin_M
        Edwin_M
        Edwin_M
        @Jack-van-Tilburg ahhh, thnx
        Now i understand the filter.
        I thought if I select 3 and all above that, all above 3 will be shown,but hat is not how it is implemented.
        It is used a a from x and above
        So I only 3 selected, 3 and above are shown as result. From 4.5 and 5 it's not a result anymore.
        Ok good to know.
        Edwin_M
        Edwin_M
        • Hide warnings on the map
          Vincible
          Vincible
        • Map Layers
          Martin White
          Martin White
          Michael 2v
          Michael 2v
        • Bollard trouble
        • Library: Folders at the Top of the Menu
