  4. Extra navigation needed in warm weather (sunlight)...
15 Posts 9 Posters 198 Views 3 Watching
    @Dikke-Wim It's a combination of both factors I guess.
    Dikke Wimundefined Offline
    Dikke Wim
    @Bart-DM
    You could be (are probably) right. MyRoute Next uses a lot of processor time and heats up the iPhone.
    Thanks for your fast reply!
    • Jörgenundefined Offline
      Use a Carplay device for bikes, then you can keep your phone in your pocket.
      • Jörgenundefined Jörgen
        richtea999undefined Offline
        @Jörgen said in Extra navigation needed in warm weather (sunlight)...:
        Hmmm. The whole point of MRA Nav Next is to avoid buying yet another device.
        https://support.apple.com/en-us/HT201678
        'Additionally, if you're navigating, your device might show this alert and turn off the display: "Temperature: iPhone needs to cool down." Navigation still provides audible turn-by-turn directions. When approaching a turn, the display will illuminate to guide you through the turn.'
        That 'approaching a turn' option may be available to MRA Nav Next, but knowing Apple it's probably specific to just their own navigation apps. One for investigation later, maybe.
          Correct, battery usage is the top priority but unfortunately part of it is HERE.
          Battery usage = high CPU usage = temperature increase
          Kudeeundefined CD130undefined 2 Replies Last reply
            @richtea999 said in Extra navigation needed in warm weather (sunlight)...:
            That may be right, but "normal" smart phones are not made for heat, rain and vibration. So may be kill better a less than 200€ device then a 1000€ smart phone. jm2c
              Kudeeundefined Offline
              Kudee
              @Corjan-Meijerink Iphone könnte das Problem sein. Mein Huawei P30 Pro wird moderat warm und wird sogar wireless geladen wärend der Fahrt. Bei Ankunft immer 90 -100% Ladung
                CD130undefined Offline
                @Corjan-Meijerink even wat testjes gedaan de afgelopen dagen. Beschik over een Quad Lock QI lader op de motor.
                20 graden
                30 minuten
                52% start
                52% stop
                MRA aan
                Scherm aan
                17 graden
                20 minuten
                42% start
                48% stop
                Google Maps aan, MRA uit
                Scherm aan
                13 graden
                20 minuten
                92% start
                97% stop
                MRA uit
                Scherm uit
                20 graden
                30 minuten
                72% start
                89% stop
                MRA uit
                Scherm uit
                Conclusie en geen verassing 🙂 :
                MRA trekt aardig wat stroom.
                  M. Schrijverundefined Offline
                  @CD130
                  Not only MRA Next. Other navigation apps also but MRA Next is clearly the winner.
                  Make sure your phone is mounted in the wind for cooling. This helps a lot.
                  @Jörgen
                  Keep the phone in your pocket with Carplay or AA is bad advice. The phone will stil get very hot.
                  Also with Carplay of AA the will need cooling.
                  • CD130undefined CD130
                    20 graden
                    30 minuten
                    52% start
                    52% stop
                    MRA aan
                    Scherm aan
                    17 graden
                    20 minuten
                    42% start
                    48% stop
                    Scherm aan
                    13 graden
                    20 minuten
                    92% start
                    97% stop
                    MRA uit
                    Scherm uit
                    20 graden
                    30 minuten
                    72% start
                    89% stop
                    MRA uit
                    Scherm uit
                    Dikke Wim
                    @CD130
                    Ik neem aan dat je in alle gevallen het scherm op dezelfde helderheid hebt gehad?
                      @CD130
                      @Dikke-Wim ja, op 100% 🙂
                      richtea999undefined
                      CD130undefined
                      Dikke Wimundefined
                      Dikke Wim
                      Kudeeundefined
                      Kudee
                        Mzokkundefined
                        3.9k
                      • Updated beta! 5.2.1 (486)
                      • Showing Tracks with Routes on the Garmin XT3
                        Steve Jarrellundefined
                        Steve Jarrell
                      • Track vs Route
                        Carl Leeundefined
                        Carl Lee
                      • MRA 5.2.1 (486) POI function- Share POI folder from the app to a friend // POI Funktion- POI Ordner aus der App an einen Freund teilen
                      • Some strange routing - Can someone explain?
