  4. Erros in generated route calculations
5 Posts 3 Posters 95 Views
  • Kenneth de Mirandaundefined Offline
    Kenneth de Miranda
    The past weekend i've had two occurences that i genererated an scenic route but that MRA, after generating the route, adviced that there where errors in certain parts of the route and that it could not be calculated.![alt text](image url).IMG_6621.jpeg
      @Kenneth-de-Miranda, The message does not say that the route could not be calculated 😉 The app checks the generated track (based on OSM maps!) against the HERE map. It is just a warning that there COULD be some unwanted u-turns, wrong directions through one-way streets and similar things in the route. You can choose to look at them, or not, and continue your navigation.
      Kenneth de Mirandaundefined 1 Reply Last reply
        Kenneth de Miranda
        @Con-Hennekens ok, gotchya.
          @Con-Hennekens @Kenneth-de-Miranda next update will containing a setting to turn these checks off 😉
            Kenneth de Miranda
            @Corjan-Meijerink aha, ok!
            Kenneth de Miranda
            • Showing Tracks with Routes on the Garmin XT3
              Steve Jarrellundefined
              Steve Jarrell
            • Track vs Route
              Carl Leeundefined
              Carl Lee
            • MRA 5.2.1 (486) POI function- Share POI folder from the app to a friend // POI Funktion- POI Ordner aus der App an einen Freund teilen
            • Some strange routing - Can someone explain?
            • Updated beta! 5.2.1 (486)
            • Return to main screen when editing a Route
              Lluis Arasanzundefined
