  4. Are these buttons still under construction because we are in the Beta version?
12 Posts 5 Posters 200 Views 1 Watching
  • PeterKerkhof
    PeterKerkhof
    PeterKerkhof
    For information.
    The following buttons work well on my phone 3, 6 and 8
    The following buttons 1, 2, 4, 5 and 7 do not work properly / do not link properly on my phone yet.
    I assume this buttons are still under construction.
    1 Laatste route
    Slowly advances to next picture but then stops and does not continue
    2 Routelab
    Doesn't go any further
    3 Routes
    Works well
    4 Bibliotheek
    Does not work
    5 Nieuwe route
    Does not work
    6 Rondrit
    Works well
    7 Prestaties
    Does not work
    8 Tracklogs
    Works well
    Keep up the good work!
    • PeterKerkhof PeterKerkhof
      For information.
      1 Laatste route
      2 Routelab
      3 Routes
      Works well
      4 Bibliotheek
      Does not work
      5 Nieuwe route
      Does not work
      6 Rondrit
      Works well
      7 Prestaties
      Does not work
      8 Tracklogs
      Works well
      @PeterKerkhof No they are not. Which phone are you using?
      đŸī¸ Tiger: DMD Nor7e + SilverFox controller
      đŸī¸ Bobber: iPhone 15 Pro + Quad Lock mount
      PeterKerkhof 1 Reply Last reply
      • Bart De Medts Bart De Medts
        PeterKerkhof
        PeterKerkhof
        PeterKerkhof
        @Bart-DM Huawei P20 lite
        The buttons do not work in MRA Next.
        They work well in MyRouteAppRoutePlanner.
        I don't know if this might be causing the problems
        https://www.androidauthority.com/huawei-google-android-ban-988382/
        Bart De Medts Con Hennekens 2 Replies Last reply
          @PeterKerkhof No idea, did you try deleting and reinstalling the app?
            @PeterKerkhof said in Are these buttons still under construction because we are in the Beta version?:
            No I don't think that is the cause. If you are still able to use the Google Playstore, your P20 is not affected by the ban. I also have a Huawei (P30 Pro) from before the ban, and experience no problems whatsoever.
            The non-functioning buttons are mostly embedded views to the online webpages. No idea what's causing the problem. Do they generate some error, an empty page, are what do they do exactly?
              All buttons should indeed work. 2, 4, 5 & 7 open a browser within the app. The others use native app features.
                PeterKerkhof
                PeterKerkhof
                PeterKerkhof
                I had made a movie from the problem,
                Can i send this movie to you via a private message.
                Becasuse I have not enough permessions to post it on the forum.
                  @PeterKerkhof you can send it to corjan@myrouteapp.com could you also attach the app logs?
                  You can get the logs from the app by going to your account page (where the settings are) > scrolling down > long press the version number.
                  Thanks!
                  • PeterKerkhof
                    PeterKerkhof
                    PeterKerkhof
                    `I have sent the video and log file to Corjan and the problem is now being investigated by MRA specialists.
                    Thanks everyone for the thoughts 👍 and the quick responses and I'll keep you posted.😊
                    Angelo Greco 1 Reply Last reply
                      Angelo Greco
                      Angelo Greco
                      Angelo Greco
                      @PeterKerkhof , I am having the same problem with Huawe P Smart 😞
                      • PeterKerkhof
                        PeterKerkhof
                        PeterKerkhof
                        @Corjan-Meijerink The problem still exists on my phone.
                        I think the code is correct for most phones but not for my type of phone. If you need more information from my side to investigate this problem, I am of course happy to provide it.
                          @PeterKerkhof very weird 😞
                          PeterKerkhof
                          PeterKerkhof
                          Angelo Greco
                          Angelo Greco
                            1.6k
                            1.5k
                          • Hoe kan ik in ÊÊn route een stuk met en een stuk zonder snelwegen plannen
                          • MyRoute-app wedding
                            10.4k
