  4. Confused waypoints and sound
3 Posts 2 Posters 79 Views
  • RetiredWingMan Offline
    Today I headed out on a ride with friends using downloaded maps and offline navigation. Shortly after setting out the waypoint number at the top skipped to the next WP #. After some time it seemed to fix itself. Later it skipped several WP to the next Viapoint. This caused problems with the time and distance calculations for route end, next WP and next VP. Navigation instructions remained correct.
    After lunch I restarted the app and route. Issues with the WP numbers continued and I also saw a white flag once.
    I also noticed that along with route update delays, the current speed display was frequently jumping up and down. Display was showing speeds well below what we were doing or well above our actual speed.
    Adjusting the volume is annoying at best. In order to adjust the volume you need to do it while directions are being spoken. This is difficult while driving with gloves and phone cases. I also noticed today that adjusting the volume of my Cardo also has to be done while instructions are being spoken.
      Corjan Meijerink Offline
      @Doug-Robinson Thanks for the feedback!
      • The "white flag" issue is something we will investigate. It would help a lot if you could share the route you were driving and indicate when it occured!
      • Delays is something we work on
      • Volume adjustment and voice configuration will be added in a future update.
      Cheers 🙂
        Cheers 🙂
        @Corjan-Meijerink here is the route: https://www.myrouteapp.com/en/social/route/4389253?mode=share
        I think the problem after WP # 3. Between WP 9 & 10 it displayed ViaP # 12 as the next WP. At that point the calculations at the bottom for next Wp, ViaP and route end were messed up. After out stop at ViaP # 12, I restarted the route at WP#13. Not long after the Next WP display was ahead again. I'm not sure when the white flag was displayed, Somewhere after WP # 20 I think. It disappeared after the next WP. Hope this helps.
        • Carpuride scherm vast
          De Ploey Georges
          De Ploey Georges
          1.3k
          14.5k
        • Camperroutes
          De Ploey Georges
          De Ploey Georges
        • Not a great route choice
