  3. "Expand" not working...
21 Posts 5 Posters 5.8k Views 2 Watching
    @Laurence-2
    When you create a new route from scratch expanding is working also in the Here-map. Maybe it is the route that you uploaden that gives the problem.
    Create a new route and make the uploaded route visible via the left menu (routes) and then place routepoints to draw the route.
    Laurence 2
    Laurence 2
    Laurence 2
    @Hans-van-de-Ven-MRA-Master
    I remade the route and still same issue - won't expand for me.
    This is the link:
    https://www.myrouteapp.com/en/social/route/7387652?mode=share
    I started making this route by importing waypoints from a Mapsource GPX file. These appear in the MRA map as POI's. Then, I enable these POI's in Library. When linking them to make the route, I tick the box to make them into waypoints.
    Not sure if my procedure is correct. Anyway, this is where I suspect the problem with not expanding stems from - importing waypoints....
    Rob Verhoeff HABVEN aka MrMRA 2 Replies Last reply
    • Laurence 2 Laurence 2
      This is the link:
      @Laurence-2 and @Hans-van-de-Ven-MRA-Master I'm sure the original route isn't well put together. Shaping points are not all placed in the middle of the road. In addition, there are also parts of the route that you drive there and back. The program cannot handle that. I put extra shaping point in crucial places myself and then expanded it to 60 points. That works perfectly. I think it's user error.
        This is the link:
        @Laurence-2
        When importing gpx files from other planners, always select the route-track option to import.
        When i look at your route, as @Rob-Verhoeff said, it isn't well put together
        Make sure that the routepoints are placed correct on the routeline
        Laurence 2 1 Reply Last reply
          @Laurence-2
          Laurence 2
          Laurence 2
          Laurence 2
          I appreciate the advice.
          The POI's are not all on roads, as they are photo points for a photo rally.
          I am not clear why MRA cannot manage this situation, but have to accept it.
          I moved from Zumo 660 + Mapsource to Zumo XT + MRA - let's say the jury is still out.
            @Laurence-2
            MRA can handle it, but when a notmal routepoint is placed that way, we think it is off track.
            If point 3 is a photo stop, make a viapoint of it. Then you will be forced to visit that point. And you will see the flag in your XT.
              @Laurence-2
              Laurence 2
              Laurence 2
              Laurence 2
              That is good advice thanks.
              I have to learn to use such POI's as a guide while creating actual waypoints nearby for the route purpose.
              The XT presents it's own challenges.... I miss the "please drive to highlighted route" instruction which the 550 / 660 provided when you want to join a route from which you have detoured. I still do not have a consistent solution to use for this on the road. Any advice would be appreciated.
                Laurence 2
                Laurence 2
                Laurence 2
                @Laurence-2
                Hello again,
                I have another route of 17 waypoints, made on MRA only, without anything imported.
                I cannot get the Expand function to work, I tried adding different numbers of waypoints (50, 100)
                Can anyone advise what is the issue preventing addition of waypoints in this way, please?
                Route link: https://www.myrouteapp.com/en/social/route/7392943?mode=share
                Thanks,
                LB
                Rob Verhoeff Lynchy67 2 Replies Last reply
                  @Laurence-2
                  Hello again,
                  Thanks,
                  LB
                  @Laurence-2 It's working for me! There are some point that have a critical position in your route such as 13 and 3. After moving point 13 and 3 I succedes in expending the route. Sometimes you see a little gap between two points. Move that point and than it will work. You have to carefully place the points. Not on a intersection, but a little further away.
                    @Laurence-2
                    Hello again,
                    Thanks,
                    LB
                    @Laurence-2
                    Using your Route directly I could not Expand it!
                    I have no clue why?
                    Maybe one of the Dev's can look at that?
                    So I saved it as a GPX1.1 (Track, POI) then re-imported it as a Route-Track.
                    Then when I "Edit route-track" it works.
                      Laurence 2
                      Laurence 2
                      Laurence 2
                      @Rob-Verhoeff
                      Rob,
                      I did as you said:
                      Revised the waypoint locations to be away from junction, a little beyond the intersection and exactly on the route. I then was able to expand the route to 50 waypoints. This will be more secure for transfer to the XT and if I go to share the route.
                      So, now I know!
                      Thanks,
                      Laurence
                      • Lynchy67 Lynchy67
                        @Laurence-2
                        I have no clue why?
                        Laurence 2
                        Laurence 2
                        Laurence 2
                        @Lynchy67
                        Hi Lynchy,
                        Thanks for that work-around, good to know!
                        Laurence
                        • simonharvestmill.co.uk
                          I'm having the same problem, I've used Espand many times with no hitch but now I am having the same issue
                          https://www.myrouteapp.com/en/social/route/7413027?mode=share
                          If it's relevanty this route was originally part of a single longer route and I split it. I suceesfully expanded the first half
                          • simonharvestmill.co.uk simonharvestmill.co.uk
                            @Simon-Wood I think your route looks a bit like a mess. What is the meaning of waypoint 4 between 12 and 13?
                            The other points ensure that a loop is constantly made. I understand that the expand function can't handle that.
                            Laurence 2
                            Laurence 2
                            • MRA 6.0.0 (526) - Offline Calculation Problem
                            • MRA Studio export speed
                            • Route with one Waypoint cannot be saved
                            • Routeberekening zonder invloed van actuele verkeerssituaties en wegafsluitingen
                            • Maps Michelin
                            • Hiya from UK
                              Russ Nattrass 1
                              Russ Nattrass 1
                            • geeft routepunt niet weer
