  4. Simulating a GPX1.2 Route in MRA Navigation Next
15 Posts 5 Posters 219 Views 1 Watching
  • Con Hennekens
    @Lynchy67 said in Simulating a GPX1.2 Route in MRA Navigation Next:
    Therein lies the problem as the creation of the Track was always managed directly on the Garmin XT when using GPX1.2
    I don't think that is correct. As far as I know the track is generated during the GPX export by MRA. The GPX contains a route as well as a track (except GPX1.2 I believe but that is beyond my Zumo experience. I haven't touched it since the introduction of MRA Navigation 😉 ). On the garmin you can choose to convert the track to a trip (their take on a route) and that trip follows the track exactly.
    Lynchy67 1 Reply Last reply
      I’m the same, haven’t used the XT for ages but I do always take it with me.
      • Dikke Wim
        Dikke Wim
        Dikke Wim
        @Con-Hennekens De export van een GPX 1.2 versie bevat zowel de track als de route. Deze importeer ik in mijn BMW Navigator V en ik kan de track zichtbaar maken als een lijn, én de route gebruiken. De vormpunten zijn niet in de kaart (overzicht) of in de route te zien, de VIA punten gelukkig wel. Jarenlang heb ik Basecamp gebruikt om de track zichtbaar op mijn Navigator V te hebben én de route (en overigens ook de POI's).
        Samengevat, MyRoute App (website) exporteert via GPX 1.2 zowel de POI's, de track en de route. Op een Garmin of Navigator V of VI kun je de track zichtbaar maken (via "Sporen") en in beeld houden op de kaart.
        Suggestie: Een zichtbare track zou in MRA Navigation Next heel erg welkom zijn!
        BMW R1300 GS, BMW Connect Ride Next navigator; Quad Lock with Samsung Galaxy Ultra, iPad Pro (iPadOS 18.0 bĂšta version) MacBook Pro (MacOS Sequoia 15.2 bĂšta version), iMac (MacOS Monterey 12.7.6)
          With route navigation we are able to hide shapingpoints from the map but they will always be used for the internal route calculation. So even if we hide them from the map - the upcoming waypoint will always show the shapingpoints too. If we also only show viapoints in the upcoming waypoint then skipping points will have very weird side effects.
          Example: you have a route with start - 20x shaping - 1x via (call this A) - 10x shaping - 1x via (call this B) -
          If we would only show via points and you skip one while you are at the start of the route you would therefore skip A meaning that the app will start routing you to B. That means that the fastest route will be calculated from your position to B. Skipping a total of 30 shaping points. Easy conclusion: upcoming waypoint must show them all.
          If you want to skip to the next via point? Just use the waypoint list.
          Hiding shapingpoints from the map? That’s possible but will more likely lead to more confusion rather than less. You won’t see the points that are actively used for route calculation.
          Now track navigation. We could show via points on the map but they won’t be included in the route calculation and you can’t have any interaction with them. Again: probably more confusing.
          Not an easy discussion 🙂 Especially for now we shouldn’t make it too confusing for the mass.
          Lynchy67 Dae 0 2 Replies Last reply
            You bring up things behind the scenes that I never considered.
            I get it now though, so I am happy to retract my request for GPX1.2 style routes.
            I actually don't mind seeing Waypoints, as someone who literally puts at least one Shaping Point on every road I travel on just to ensure that the HERE map doesn't make decisions for me.
            I only use routes if "she who must be obeyed" is out on the bike with me.
            If I am out on my own its always a Route-Track.
            For me the app is perfect the way I use it, and I say that knowing there is still more to come.
            We have a bank holiday weekend in the UK this week, the Tiger will definitely getting its legs stretched.
            Enjoy the weekend.
            • Lynchy67 Lynchy67
              Enjoy the weekend.
              @Lynchy67 happy stretching! 🙂
              Yeah some requests may seem possible (or even easy) but technically they can be far more difficult.
                Dae 0
                Dae 0
                Dae 0
                @Corjan-Meijerink said in Simulating a GPX1.2 Route in MRA Navigation Next:
                This is purely a question for my own understanding, but in this scenario why would the app not try and route from the current position to the first shaping point after A in the same manner it would if you’d just “visited A”?
                • Dae 0 Dae 0
                  @Dae-0
                  Like you I also like to test my understanding.
                  I think the answer lies in the fact that @Corjan-Meijerink was actually describing a scenario where the Shaping Points are actually hidden.
                  Dae 0 1 Reply Last reply
                  • Lynchy67 Lynchy67
                    @Dae-0
                    Dae 0
                    Dae 0
                    Dae 0
                    @Dae-0
                    That’s what I thought initially, but it contradicts the statement “we are able to hide shapingpoints from the map but they will always be used for the internal route calculation”
                    • Dae 0 Dae 0
                      @Dae-0
                      @Dae-0
                      That confused me too.
                      I can only presume that @Corjan-Meijerink means that they can hide them but they won't do it?
                        Hahah yeah, sometimes writing down my thoughts gets unstructured.
                        So basically:
                        • hiding shapingpoints visually from the map is easy but is confusing as they are still used actively in calculating. The upcoming waypoint will still show shapingpoints
                        • hiding shapingpoints from the upcoming waypoint button (used to skip) will result in very weird skipping behavior as you couldn’t skip a single shapingpoint but would skip to the next viapoint which could be a very large jump
                        • track navigation cannot use any waypoints by design, we could show them (or only viapoints as with gpx1.2) on the map but that would be confusing too as they would be purely visual and wouldn’t offer functionality.
                        Hope that sums it up well 🙂
                          So basically:
                          I am not sure if I agree with this completely. Viapoints, and also shapingpoints can be colored (which has a meaning) and notes (that usually have a purpose). Showing those on a track may have no value for calculations, but certainly for informations.
                          Dikke Wim
                          Dikke Wim
                          Dae 0
                          Dae 0
                          • My Routeapp Stays questions
                          • Help please, new user
                            Bull Tahr
                            Bull Tahr
                          • Foutmelding In MRA Next
                            Hans Lamers
                            Hans Lamers
                          • Strange translation
