  3. [App-Beta] Announcements
  4. New Beta! (v3.2.13)
New Beta! (v3.2.13)
41 Posts 11 Posters 952 Views 2 Watching
  • Pete Fredette
    Pete Fredette
    Pete Fredette
    Awesome on the updates!
    Since I leave in the AM when it's still dark out, when do you expect an update so CarPlay is in dark mode? It's to bright now.
      Hi everybody! 👋
      We've got a nice new update for you! This time, we paid a little more attention to Android 😉 (no worries iOS users, we also got some CarPlay improvements).
      Position indicator
      Some testers made some fun that if I had a few hours left, we should be able to add customisation options to the position indicator. Some want a different color, some want the circle to be visible and others are happy with how it is. Rejoice! More customisation options 😏
      CarPlay
      The changes above als apply to CarPlay! 😃
      Furthermore, the issue where sometimes an incorrect (the previous) maneuver was shown, has been fixed!
      Also, CarPlay now also uses the new (correct) roundabout icons.
      External storage (Android)
      If you don't have enough capacity on your phone and need to use external storage, that's possible! 🎉
      Android stability
      The same issue iOS had last week (https://forum.myrouteapp.com/topic/3721/ios-3-2-12-issue) which resulted in an immediate update, also caused some (less obvious) issues on Android. This now also has been fixed.
      But most importantly! The issue which resulted in random crashes over the past months when using the app / starting your navigation has been fixed! 🎉 This means that as this point, Android should have a good stability.
      Have a great weekend and we're looking forward to all your feedback as usual 🙂
      Cheers,
      Corjan & Joost
      roland herremans
      roland herremans
      roland herremans
      @Corjan-Meijerink heel leuk is de update reeds beschikbaar
      • Pete Fredette Pete Fredette
        @Pete-Fredette not sure when 😉
          @Corjan-Meijerink Today I spent a few hours navigating with the app while charging the smartphone with a Quad Lock wireless charger on my motorcycle. At the end of the ride, the phone's battery was charged to 100% and the device did not feel hot. So 👍 👍 👍 👍
          Ian foster 0 1 Reply Last reply
          • Bart De Medts Bart De Medts
            Ian foster 0
            Ian foster 0
            Ian foster 0
            @Bart-DM yes same with my iPhone 12 last weekend , 5 hours ride and no discharge or heat
              Hi everybody! 👋
              Position indicator
              CarPlay
              Android stability
              Cheers,
              Corjan & Joost
              G.Grote Ganseij
              G.Grote Ganseij
              G.Grote Ganseij
              @Corjan-Meijerink ik heb afgelopen weekend en gisteravond nog nog gereden, en het volgende viel mijn op dat de kaart niet van 2D naar 3D kantelt, als je bv bij een rotonde aan komt zoemt hij in en de kaart kantelt ben je die voorbij kantelt hij weer terug naar 2D en zoemt uit, dit heb ik na de laatste update hij blijft nu de hele route 3D staan. En de afslagen worden niet consequent in spraak door gegeven, ik krijg de indruk dat hij bij provinciale het wel wordt aangegeven en de klein sluipdoor kruipdoor wegen niet in spraak wordt aangegeven. Ik zou vanavond nog gaan rijden is er niet van gekomen ik had in de app de vormingspunten uit gezet en zins dien heb ik het idee dat geen spraak geeft bij elke afslag die ik tegen kom. en nee ik heb niet de audiowaarschuwingen uit gezet. Gisteren avond heb ik de MyRoute-app opnieuw geïnstalleerd. morgen ga ik rijden met de vormingspunten aan kijken wat hij nu doet. P.S. ik gebruik Android op de Samsung tablet.
                Hi everybody! 👋
                Position indicator
                CarPlay
                Android stability
                Cheers,
                Corjan & Joost
                Dikke Wim
                Dikke Wim
                Dikke Wim
                @Corjan-Meijerink Undoubtly a stupid question: how can I get the update to v3.2.13?
                I tried both the TestFlight App and the App Store App: no success.
                Ian foster 0 Bart De Medts 2 Replies Last reply
                • Dikke Wim Dikke Wim
                  Ian foster 0
                  Ian foster 0
                  Ian foster 0
                  wrote on last edited by Ian foster 0
                  @Dikke-Wim Apple is normally a few hours after android before it’s released
                    @Dikke-Wim Via TestFlight, but the update isn’t available yet… it takes a few hours.
                    Dikke Wim 2 Replies Last reply
                      Dikke Wim
                      Dikke Wim
                      Dikke Wim
                      @Bart-DM Thanks! Good to know.
                        Dikke Wim
                        Dikke Wim
                        Dikke Wim
                        @Bart-DM Even after 12 hrs: Still no update available... Am I doing something wrong?
                        Bart De Medts Corjan Meijerink 2 Replies Last reply
                          @Dikke-Wim no, update isn’t available yet… on iOS 
                          • MotoCon
                            Could still not find the update, but checked and I see it has been installed automatically (Android).
                            Offline maps needed an update, but would not complete that update.
                            After clearing data an cache I was able to re-download the maps.
                              @Dikke-Wim you will automatically be notified on TestFlight, give it some time 😉 No need to panic.
                                @Corjan-Meijerink I don't panic, but admit it does take a long time this time 🙃
                                  Hi everybody! 👋
                                  Position indicator
                                  CarPlay
                                  Android stability
                                  Cheers,
                                  Corjan & Joost
                                  Dikke Wim
                                  Dikke Wim
                                  Dikke Wim
                                  @Corjan-Meijerink Any clue when the new version will be available in the Netherlands?
                                    @Dikke-Wim update is available.
                                    Dikke Wim Corjan Meijerink 2 Replies Last reply
                                      Dikke Wim
                                      Dikke Wim
                                      Dikke Wim
                                      @Bart-DM Yes, thank you Bart 👍 Downloaded it immediately 😳
                                        @Bart-DM Apple took its time 🙂
                                        Bart De Medts 3 Replies Last reply
                                          @Corjan-Meijerink yes indeed 😂
                                          Dikke Wim
                                          Dikke Wim
                                          roland herremans
                                          roland herremans
                                          G.Grote Ganseij
                                          G.Grote Ganseij
                                          Steve Lynch
                                          Steve Lynch
                                          Franz van Lammeren
                                          Franz van Lammeren
                                          Ian foster 0
                                          Ian foster 0
                                          Pete Fredette
                                          Pete Fredette
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                            Mosimann
                                            Mosimann
