  3. [App-Beta] Announcements
  4. New Beta! (v3.2.12)
New Beta! (v3.2.12)
85 Posts 23 Posters 863 Views 6 Watching
  • Dae 0 Dae 0
    I just got the iOS update, but now the app won’t even start - it just crashes.
    Even tried an uninstall and reinstall but it’s the same.
    Ian foster 0
    Ian foster 0
    Ian foster 0
    @Dae-0 Mine crashed twice then on the 3rd time all working
      Very sorry for the inconvenience. We will investigate it with the highest priority 🙂
        That’s very strange. In TestFlight you can also select the previous version. Simply open the app details in Testflight and scroll down to “previous builds” @Albert-Renting @Bart-DM @Arno-0 @Dae-0 @MarcM @arcangelenruta
        Albert Renting
        Albert Renting
        Albert Renting
        @Corjan-Meijerink Did install the previous version as per your message and it works again (on the v3.2.11 version)
        I'll wait for the next update or message that this problem is solved.
        Thanks for the tip!
        • Ian foster 0 Ian foster 0
          @Ian-foster-0 Very occasionally the app starts, but mostly it crashes.
          @Corjan-Meijerink Don't worry, this is part of a beta 😊
          Corjan Meijerink Lynchy67 2 Replies Last reply
          • Bart De Medts Bart De Medts
            @Bart-DM thanks for being understanding 🙂 I do apologise
            Bart De Medts Rob Verhoeff 2 Replies Last reply
              I’ve rolled back to 3.2.11 on iOS
              • arcangelenruta
                arcangelenruta
                arcangelenruta
                In case it's helpful, I've updated the App at home and it didn't work. I have turned off the Wi-Fi connection, and when I opened it with LTE connection it has started to work. Now it works with wifi and LTE
                Congratulations on the work, these things can happen with such a complex project
                Rafael Rodriguez
                Honda GL1800BD Goldwing
                Dae 0 1 Reply Last reply
                  @Corjan-Meijerink Absolutely no need!
                  Btw, when the app opens, the new features work perfectly 😊
                  • arcangelenruta arcangelenruta
                    Dae 0
                    Dae 0
                    Dae 0
                    @arcangelenruta said in New Beta! (v3.2.12):
                    I get crashes regardless of Wi-Fi or mobile network. I’ve not managed to open the app at all
                      @Corjan-Meijerink No worries. It's all in the game. I think you revoked the update? I don't see it anymore.
                      • Dae 0 Dae 0
                        The latest version has disappeared.
                        • Joost van Someren
                          Joost van Someren
                          Joost van Someren
                          Hi everyone, noting all the crashes for iOS users I've pulled the latest release from Testflight. Currently I'm in the progress of uploading a new version to Testflight with a fix for the issue. Hopefully we'll get this new release to you guys by tomorrow morning!
                          Corjan Meijerink Bart De Medts 2 Replies Last reply
                          • Joost van Someren Joost van Someren
                            @Joost-van-Someren the absolute hero of the evening! 🎉 Without this man the app wouldn’t even exist 🙂
                              @Joost-van-Someren thx!!
                                #51
                                Communication regarding iOS: please continue here https://forum.myrouteapp.com/topic/3721/ios-3-2-12-issue
                                Edit: update already available!
                                  Happy Friday! 👋
                                  You probably are getting used to weekly updates by now. Obviously we want you to enjoy the sunny weather ☀ and what better way to that on the bike with a freshly updated app 😏
                                  This update has quite some nice changes!
                                  Improved roundabout exit indication
                                  Finally! A massive frustration for quite some users. Our roundabouts always assumed symmetrical exists. But no, that is barely ever the case. The roundabout exits now show exactly what direction the exit is you need to take including the correct exit number 🎉
                                  Offline routing
                                  Who is looking forward to a internet free drive? I am! 😃
                                  If you've downloaded the offline maps of the region you are driving through, you can now use the app completely in offline mode. The long awaited setting for this has now been activated.
                                  Routing somewhere and you don't have the offline maps for that location? The app will ask you to go online!
                                  Routing somewhere and your internet connection is gone? The app will ask you to go offline! 🎉
                                  Other changes
                                  • Position indicator circle color / visbility
                                  • Improved camera behavior for a better depth view in landscape mode (and CarPlay)
                                  Bug fixes
                                  • Issue where route would recalculate after passing a waypoint
                                  • Position location indicator on screen not always correct after rotating
                                  • Compass button not always reacting to a tap
                                  • Menu button not always opening the menu / not able to interact with items on map
                                  That's it for now! 🙂
                                  We continue working on the battery drain / position delay / Android stability / Android Auto! 💪 Besides that we obviously process all your feedback and continue checking other requirements such as in this update 😉
                                  Have a great weekend!
                                  Best,
                                  Team MRA
                                  @Corjan-Meijerink said in New Beta! (v3.2.12):
                                  Offline routing
                                  I couldn't download an offline map after installing 3.2.12-165. I switched back tot the previous version, downloaded the Dutch map and then re-installed 3.2.12-165. Then I could download maps again.
                                  Strange!!! 🤔
                                  Bart De Medts Corjan Meijerink Arno 0 3 Replies Last reply
                                    Offline routing
                                    Strange!!! 🤔
                                    @Rob-Verhoeff I don’t have that problem.
                                      Happy Friday! 👋
                                      Offline routing
                                      Other changes
                                      Bug fixes
                                      Best,
                                      Team MRA
                                      #54
                                      @Corjan-Meijerink I was able to test the latest  version properly today. Everything works fine, also the new depth view on CarPlay is a big step forward 👏 .
                                      I do have one small request: can the navigation arrow in the app (not in CarPlay) be made a bit bigger? In CarPlay it's perfect, but in the app I really think it's a bit too small.
                                        Offline routing
                                        Strange!!! 🤔
                                        @Rob-Verhoeff strange indeed 🙂
                                          @Bart-DM could you create a separate suggestion for that, easier to keep track of. Please include a screenshot of your pretty ass CarPlay resolution screen.
                                          The position indicator is not resolution aware, that would be the fix 🙂
                                          • 4
                                          • 5
                                          Rolf Engelsman
                                          Rolf Engelsman
                                          Dae 0
                                          Dae 0
                                          Richard 18
                                          Richard 18
                                          MarcM
                                          MarcM
                                          arcangelenruta
                                          arcangelenruta
                                          Arno 0
                                          Arno 0
                                          Albert Renting
                                          Albert Renting
                                          UltraStar
                                          UltraStar
                                          Vlad Popovici 0
                                          Vlad Popovici 0
                                          flamingm0e
                                          flamingm0e
                                          Ian foster 0
                                          Ian foster 0
                                          jan oosterling
                                          jan oosterling
                                          Joost van Someren
                                          Joost van Someren
                                          • MRA 6.0.0 (526) - Offline Calculation Problem
                                          • MRA Studio export speed
                                          • Route with one Waypoint cannot be saved
                                          • Routeberekening zonder invloed van actuele verkeerssituaties en wegafsluitingen
                                          • Maps Michelin
                                          • Hiya from UK
                                            Russ Nattrass 1
                                            Russ Nattrass 1
                                          • geeft routepunt niet weer
