  4. Battery Drain still an issue
14 Posts 10 Posters 319 Views 3 Watching
  • Christopher M Kelly
    Christopher M Kelly
    Christopher M Kelly
    I have an iPhone 11 Pro Max using version 3.2.11 (163). It's mounted on a Quadlock wireless charging mount which could not keep up with the battery drain.
    The MRA drain was 7% in 1hr 39mins, Waze drained 3% in 4hr 11min
    I ride for work, I work to ride
    • Christopher M Kelly Christopher M Kelly
      @Christopher-M-Kelly correct. We are tackling this. In the last update we added enhanced analytics to aid us in solving the issue 🙂
        @Corjan-Meijerink if that's so, how can we provide feedback specifically related to this subject? I suspect the info is only shared through crash reports?
          @StefanHummelink we’ve added more detailed logging in the last update that helps us. But in all honesty we just need to put in more hours 😉 Past weeks were mostly about new features and CarPlay 🙂
          Once we really start digging into this matter, we will be able to fix it
            Even with only tracking the route, the battery consumption is on the high side.
            • lamelylounges
              lamelylounges
              lamelylounges
              What's the latest on the battery drain issue?
              I am using Samsung Note 20 Ultra and I saw huge battery drain. I think it was probably May 2023, and haven't trusted the app because it drained my phone to death and I was stranded in the middle of nowhere.
              Are people happy with battery performance or still seeing a big battery drain?
              Thanks!
              Drabslab Corjan Meijerink 2 Replies Last reply
              • lamelylounges lamelylounges
                Thanks!
                @lamelylounges it is still the same. Seems to depend on HERE itself but i had to leave for italy using TomTom.
                I got a suggestion to use a phone charger with a larger powrr output. That did help but i could fry eggs on the phone so i stopped that out of fear of killing the phone.
                  Thanks!
                  @lamelylounges HERE is working on the issue but yeah, it remains a challenge.
                  Personally I experience no real issues when closing other apps and enabling battery saving - not ideal but doesn’t cause any issues.
                  Marinus van Deudekom Jan Weerheim Tom Cat lamelylounges 4 Replies Last reply
                    @Corjan-Meijerink even wi5h all the other apps closed thé battery drain is huge and yes thé phone gets very hot. When I use thé phone only running MRA it still gets hot and the battery is drainer from full to empty in about 3 hours. If You want it to running the whole trip You must attach it to a Power source, in my case a wireless charging Quadlock. By charging it thé phone gets warmer, witch is normal but 5he quadlock can’t keep up so thé battery gets drained
                    I sûre Hope thé problem gets solved in thé naar future bécasse like this thé app is less useful
                    I do havé Fatih in thé team so I’m sûre that they do anything possible to fix it.
                    Thé Here situation might be ânonner problem itsekf. Are they willing to solve it from there end because MRA is surélevé compétition for Garmin. On thé other hand I assume that MRA is oaying for thé use Off thé Here Cards so they must Provide a product without issues
                    Staying hopefull
                      Jan Weerheim
                      Jan Weerheim
                      Jan Weerheim
                      @Corjan-Meijerink ik herinner me dat toen tomtom overging van tomtom go mobile naar de nieuwe tomtom navigation app, het stroomverbruik en warm worden ook een issue was. Ik weet niet welke kaart zij gebruiken maar dat heeft toen ook enige tijd gekost voordat ze het opgelost hadden. Misschien voegd dit niets toe maar toch, misschien heb je een vriendje bij tomtom 😉 Succes met het vinden van een oplossing. Ik kan niet wachten tot de nieuwe google car play update uitkomt 😄
                      • Jan Weerheim Jan Weerheim
                        @Jan-Weerheim, relaties buiten de eigen werkkring zijn verboden... 🤣
                          Tom Cat
                          Tom Cat
                          Tom Cat
                          @Corjan-Meijerink said in Battery Drain still an issue:
                          Just to confirm, enabling battery saving does not negatively impact the MRA Next operation at all?
                          • Tom Cat Tom Cat
                            @Tom-Cat no!
                              lamelylounges
                              lamelylounges
                              lamelylounges
                              @Corjan-Meijerink thanks for the response.
                              I'll try to find some time where I can fiddle with my phone settings and do a couple hours of riding where I won't mind if I hit problems.
                              Some rides are okay to have problems and others are not.
                              I appreciate what you guys are doing and I think it's going to be a great app.
                              -Sam
                              Jan Weerheim
                              Jan Weerheim
                              Tom Cat
                              Tom Cat
                              lamelylounges
                              lamelylounges
                              Christopher M Kelly
                              Christopher M Kelly
                              • Strange translation
                                martin-phogel.de
                                martin-phogel.de
                                10.9k
                              • Undo/Redo tool is hidden
                              • Shared toggle switch
                              • Crazy routing
