  4. Offline maps
Offline maps
19 Posts 8 Posters 395 Views 1 Watching
    @Tom-Wilmot Offline maps is currently being worked on! We expect this to be finished within February 🙂
    Renaming favorites is not yet supported within the app yet, something that will definitely be added later!
    Tom Wilmot Offline
    Tom Wilmot Offline
    Tom Wilmot
    @Corjan-Meijerink great to know. Thank you
    Do not fear - I’m well aware of the limitations of beta apps so will keep coming back to it! I’ve invested in Gold so I want it to be a success! Thanks for the reply and keep up the good work.
    • Tom Wilmot Tom Wilmot
      Corjan Meijerink Offline
      @Tom-Wilmot Thanks! 🙂
      • Walter Coady Offline
        Walter Coady
        I'm not sure if I'm in the right area. If not please point me in the right direction. I cannot download offline maps. I thought I had posted the screen shots from my phone but never got a response, or I have overlooked a response.
        • Walter Coady Walter Coady
          Nick Carthew Offline
          @Walter-Coady Open the app and click the menu (3 horizontal lines top left)
          Now click the settings icon (top right)
          Offline maps are below Navigation Settings.
          Walter Coady 1 Reply Last reply
            Walter Coady
            @Nick-Carthew Nick, I'm aware of how to navigate to offline maps, here are the steps just in case I missed a step. The app will not allow me to download them.MyRoute1.jpegI press the three lines and get this screen >MyRoute2.jpeg I then press the figure in upper right MyRoute3.jpeg Then select off line maps MyRoute4.jpeg and then get the following!My Route 6.jpeg
              @Walter-Coady I’d recommend restarting the app completely. If that doesn’t help try reinstalling.
              Patrick Roozen 0 1 Reply Last reply
                Patrick Roozen 0 Offline
                Patrick Roozen 0
                @Corjan-Meijerink I don't want to hijack this thread but I have downloaded the offline maps I wanted in the Beta version (currently 3.2.10). That worked for me, but I cannot enable the offline maps. I have restarted the app and I have also reinstalled the app (and had to redownload the offline maps). But I still cannot enable the offline map use.
                Actually the only switches that can be enabled are the ones that are already enabled in the image above.
                iPhone 15 iOS 17.6.1
                • Patrick Roozen 0 Patrick Roozen 0
                  @Patrick-Roozen-0 Offline routing (which is what the switch does) is disabled on purpose. Offline maps are already supported but you still require internet to (re)calculate routes.
                  Once that is supported - the offline mode preference will be enabled to toggle 🙂
                    Patrick Roozen 0
                    @Corjan-Meijerink Thanks for the clarification!
                      @Patrick-Roozen-0, An attempt to clarify any further: Offline navigation is not equal to offline maps. Offline maps wil be used in preference to online maps as it already stands. Offline navigation will enable starting a route without having an internet connection available. As it stands that needs yet te be implemented, but offline maps are available, so losing the internet connection while navigating will still work.
                      • Patrick Roozen 0 Offline
                        Patrick Roozen 0
                        @Spili Look in this thread to see if that helps you.
                        Spili 1 Reply Last reply
                          Spili Offline
                          Spili Offline
                          Spili
                          @Patrick-Roozen-0
                          Thx.
                          Same problem as here...
                          Something went wrong.
                          Even after reinstall app...
                          • Corjan Meijerink Offline
                            @Spili I've sent you a personal message
                            Spili
                            Spili
                            Tom Wilmot
                            Tom Wilmot
                            Patrick Roozen 0
                            Patrick Roozen 0
                            Walter Coady
                            Walter Coady
                            • Paar onduidelijkheden.
                            • Route app reageert niet
