  4. Layout MRA toppart
Layout MRA toppart
10 Posts 5 Posters 228 Views 1 Watching
  • Robinekeundefined Offline
    Robineke
    When I am working in a map (UK) it would be nice to have the root search (Mijn routes/zuid En..) directly on top instead of first clicking on pagina menu.
    All complements to work done sofar.
    Regards Rob
    • Robinekeundefined Robineke
      Regards Rob
      @Robineke try making your browser window a little larger/full screen.
      Robinekeundefined 1 Reply Last reply
        Robineke
        @Herko-ter-Horst It is already full screen.
          @Robineke, You probably have to play a little with the zoomfactor in your browser then. I have a full HD screen:
          Zoomfactor in Chrome 100%
          Zoomfactor 125%
          Willy DEOMundefined Robinekeundefined 2 Replies Last reply
            Zoomfactor 125%
            Willy DEOMundefined Offline
            Willy DEOM
            @Con-Hennekens J'ai rencontré le même problème avec un écran 15,6. Il suffit de réduire le zoom à 90 ou 80 %
              Zoomfactor 125%
              Robineke
              wrote on last edited by Robineke
              @Con-Hennekens For sure I do something wrong. i have a complete different screen compaired to yours. This is on a laptop with 17"screen.
              Steve Lynchundefined Con Hennekensundefined 2 Replies Last reply
                Steve Lynchundefined Offline
                Steve Lynch
                @Robineke
                See the process below.
                This is the mobile view
                Click the Elipse Button top right (3 dots)
                Reduce zoom level using the minus button until you see the Desktop version shown below.
                80% - 90% will usually be enough.
                You are now in the Desktop view.
                  @Robineke, did you try the zooming? In my experience high resolution laptop screens are often set back to non-native resolutions that can cause this effect. It makes software think there is not enough pixels. Check your screen resolution, set it to native resolution (shown as "recommended" in settings) if not already. If menu text is shown too little for your eyes, compensate using the zoomfactor in settings, but only do that if necessary.
                  Next step is too ensure your browser is set to 100% zoom. If that still does not give you the "normal" menu, you can decrease to a percentage lower than 100%. That happens only on very low resolutions. I cannot imagine having a 17" (big) laptop, you would have low native resolution graphics (or it must be very old...)
                  If still not working as intended, please make the same screenshots as I just did, and show those.
                    Robineke
                    hello Con, Thank you for the support. Indeed the zooming was the issue.
                    Now set to 110% and works as you demonstrated.
                    Perfect and thank you again.
                    Kind regards Rob
                      Kind regards Rob
                      @Robineke, You're welcome. Glad I could help!
                      Robinekeundefined
                      Robineke
                      Steve Lynch
                      Willy DEOMundefined
                      Willy DEOM
                        2.3k
                      • Ik ben benieuwd naar jullie instelling
                        Nomko Nomdenundefined
                        Nomko Nomden
                      • Android GO Edition with latest upgrade
                        Michael Doherty 0undefined
                        Michael Doherty 0
                      • Why does the current location finder disappear
                        Albert van den Elsenundefined
                      • cant use app just to view map when riding
                      • How do I follow a track not Navigate it
                      • Does waypoint have to be on Route Line?
                      • using GPS coordinates for planning not always correct
                        Guztundefined
                        Guzt
