  4. Setting for less messages about waypoints doesn't work?
3 Posts 2 Posters 67 Views 1 Watching
  • infoevertkuiken.nlundefined Offline
    infoevertkuiken.nl
    Yesterday I rode my first route using MRA. I noticed I get a lot of messages. Even about shaping points and other waypoints. (See my item about less voice guidance in the suggestions forum). Either I don't understand how silencing MRA calling off shaping and via points works or there is a bug. Even after disabling calling off shaping points and via points, they still sometimes get called off. In this route https://www.myrouteapp.com/nl/social/route/7014230?mode=share point 41 was not called off, point 42 was. With the same settings. So what is the difference? Both are shaping points.
    Also I have the impression that if calling off shaping and via points is set to off, guidance near those waypoints is also muted. Is that possible?
    • infoevertkuiken.nlundefined infoevertkuiken.nl
      @Evert-Kuiken We will definitely add more configuration options later! With regards to the issue about waypoint prompts still being spoken, we'll investigate! 🙂
      Thanks for sharing the route, that helps a lot!
        The issue has been fixed in the upcoming update! 🎉 We aim to release it at the end of this week 🙂
        infoevertkuiken.nl
        • Am I using it wrong?
          Kerry Lebelundefined
          Kerry Lebel
        • Spoken streetnames
          GT JWRundefined
          Gos Kuusundefined
          Gos Kuus
        • RX routes
          1.6k
          Papasmurf2undefined
          Papasmurf2
          1.4k
