  4. 3.2.6-147 Still Crashes
9 Posts 4 Posters 179 Views
  • Vince Hyde
    Vince Hyde
    Vince Hyde
    I still have the app crash when I open a route about 60% of the time, this happens on two different Samsung phones.! Screenshot_20230114_003832_Device care.jpg
    • Vince Hyde Vince Hyde
      @Vince-Hyde Did you completely uninstall the old app including the clear cache step?
      Tim  Thompson Vince Hyde 2 Replies Last reply
        Tim  Thompson
        Tim  Thompson
        Tim Thompson
        @Corjan-Meijerink said in 3.2.6-147 Still Crashes:
        I am experiencing the same. And in my case, the answer to the above question is Yes.
          Vince Hyde
          Vince Hyde
          Vince Hyde
          @Corjan-Meijerink Yes i uninstalled it and cleared cache and even restarted the phone before a new clean install.
          when i open a route it will show it and when I click on start it crashes 60 to 70% then if I try again it will work 70% of the time on the second attempt.
          • Tim  Thompson
            Tim  Thompson
            Tim Thompson
            I'd say that this stability problem has gotten worse compared to the last version of the software/beta.
            I'm lucky to get it to successfully open a route 1 out of every 10 attempts. Once opened it often crashes when I tell to to start navigating.
              Could you by any chance detect a pattern in the crashes?
              We have been able to resolve the Android crash issue affecting some users not being able to load a route at all. The last thing we want is the app being less stable for others 😉
              These crashes are quite complex to debug so any information at all can help! 🙂 Device / Android version too!
              Vince Hyde Tim  Thompson 2 Replies Last reply
                Vince Hyde
                Vince Hyde
                Vince Hyde
                As I said I can open the app and initially it centres I think at your office the it with go to my location, i can then open a route and when I press the start 70% of the time maybe more the app closes and probably on the third or fourth attempt sometimes more it will load and run.
                this is on a Samsung S20FE and a Samsung Xcover Pro both running the latest up date.
                • Matthew Wiacek
                  Matthew Wiacek
                  Matthew Wiacek
                  I still see Android crashes.
                  I uninstalled the previous version and cleared cache before installing 3.2.6.
                  I find the same issue described above, where I can search through my routes, I then click to navigate and it crashes.
                  Since the 3.2.6 install, I have seen a new pop-up that advises clearing cache ad gives a "clear now" option.
                  I've seen this pop-up probably 3 or 4 times.
                  More often, I just try a second attempt and it will work.
                  It is a bit frustrating.
                  I'm not sure how I can capture any more details, or what info you need.
                  I'm using a:
                  Samsung A41
                  Android 12, security patch 1st Jan 2023
                  Samsung One UI 4.1
                    Tim  Thompson
                    Tim  Thompson
                    Tim Thompson
                    No not really. All I can tell you so far is that it consistently does it when I click here...
                    ... sometimes when I click here...
                    I've also noticed it randomly crash a few occasions while perusing various menus.
                    My phone details...
                    Pixel 5a
                    Android Version 13
                    Build Number TP1A.221105.002
                    MyRoute-app Mobile Version 3.2.6-147
                    • Tim Thompson Tim Thompson referenced this topic on
                    Vince Hyde
                    Vince Hyde
                    Matthew Wiacek
                    Matthew Wiacek
                    Tim  Thompson
                    Tim Thompson
                    • Adding default break times for viapoint icons
                      Lluís Casals
                      Lluís Casals
                    • Feature request: Het aanmaken en kopiëren van routes in een gedeelde bibliotheek
                      Giancarlo e
                      Giancarlo e
