  3. [Beta] Announcements
  4. Translations in the app
26 Posts 12 Posters 781 Views
  • Vlad Popovici 0 Vlad Popovici 0
    I can translate it in Romanian, if you consider it worths to add Romanian language.
    It is not a must, English is super fine for Romanians, but if you ever want to, I am here to help.
    @Vlad-Popovici-0 Thanks for your reply! Truly appreciate the kind gesture. We currently support Dutch, English, French, German, Italian and Spanish 🙂
    • Hans Kremers
      Hans Kremers
      Hans Kremers
      In het Duits word tijdsduur met ein kleine h en kleine m aangegeven, Dus 10h 35m ipv 10S 35M
      Groetjes,
      Hans
      • Hans Kremers Hans Kremers
        Groetjes,
        Hans
        @Hans-Kremers Wordt geregeld, dank!
        • b0hd1
          "Control de trayectoria" debería ser "Radar de Tramo".
          • https://t.me/MRa_by_b0hd1
          • YouTube: @demco17
            Android, Samsung X-Cover, German Version
            The old MRA-App was installed, after starting the App I got the notice of a new version for update. The update button says "offen" instead of "öffnen" to start the update.
            Sorry, could not make a screenshot, but it should be clear. I hope.
              @Jörgen Very clear, thanks!
                @Corjan-Meijerink said in Translations in the app:
                @John-Davies-2 You haven't confused me at all! 🙂
                I am happy with your feedback and already made the change (which will be applied in the next update). We do know the difference between an average speed check and a single camera. Single camera notifications are called "Speed trap" 😉
                Maybe the words Speed Camera would be more suitable than Speed trap.
                They are referred to as cameras by the UK government, police and media even though they do trap people 😁 I once disputed that it was me driving and then they sent this photo - I couldn't deny it then!
                Matthew Wiacek
                Matthew Wiacek
                Matthew Wiacek
                @Nick-Carthew said in Translations in the app:
                Just a thought on the use of the term Speed Camera.
                Other GPS devices I've used have stopped using the term Speed Camera and replaced with "Safety Zone", or "Safety Area", or simply "Hazard ahead", etc.
                I believe this is in response to changes in French law a few years back that prohibits the use of Speed Camera detection devices and GPS systems that show fixed camera locations. If you're caught with these you can get hefty fines.
                Nick Carthew Corjan Meijerink 2 Replies Last reply
                • Matthew Wiacek Matthew Wiacek
                  @Matthew-Wiacek My TomTom still refers to them as Speed Cameras. You are correct about the French law not allowing precise locations of individual revenue 😉 cameras, they have opted for safety zones, meaning anywhere between two given points of a safety zone could contain a camera. As far as I know, the data for precise locations of French cameras is not available.
                  Drabslab 1 Reply Last reply
                    @Matthew-Wiacek Thanks for the input! I do believe their law restricts users from using such devices. So regardless of the name, it just is not allowed.
                    You can turn these warnings off in the app which means we as MRA comply. The user on their end should do so if required by law.
                    I always keep it on 😉
                      #21
                      @Corjan-Meijerink I think it's unwise to make statements about the law (especially of another country), unless you're a lawyer or judge, because it's easy to get wrong. BTW, not only France has these laws (since 2012), it's also forbidden in Switzerland, Germany and a number of other countries (all with potentially different rules and consequences).
                      I don't think what you are saying is true (for France):
                      • while it does not matter what it's called, it does matter how it implemented. For example: a zone warning (a warning about a section of road instead of an exact location) is likely compliant, while a camera-warning is not.
                      • a switch to turn it off does not necessarily make MRA compliant as far as I know, unless the switch completely and permanently removes the functionality from the app.
                      See also what TomTom says about this.
                        @Herko-ter-Horst Thanks! We do cooperate with HERE on these matters so I guess we'll do some more talking about this subject 🙂
                        • Giuseppe Marino
                          Giuseppe Marino
                          Giuseppe Marino
                          for the Italian language there are some errors. where it is written STAI BENE you must write SVOLTA A DESTRA and the same will be SVOLTA A SINISTRA while where it is written LUCE ROSSA you must write TELECAMERA AL SEMAFORO.
                          Travel hours are normally indicated with the letter H and not with the letter O
                          then, as already indicated, the arrow is barely seen (under the indication of the speed limit) and often loses the gps connection even in open areas
                          • b0hd1
                            Small correction 😋. If it is more than one, in Spanish it must be in the plural (horas).
                            • YouTube: @demco17
                            • Matt
                              Matt
                              Matt
                              Hello MRA Team.
                              Here something to the translation in German.
                              You mix here personal and formal speech (in German "Du" and Sie").
                              Correct is:
                              Entscheide Dich
                              Möchtest Du diese Route...
                              IMG_2234.PNG bolded text
                                that is correct, and many camera's do NOT appear as safety zone either...
                                • Corjan Meijerink Corjan Meijerink unpinned this topic on
                                Giuseppe Marino
                                Giuseppe Marino
                                Matthew Wiacek
                                Matthew Wiacek
                                Vlad Popovici 0
                                Vlad Popovici 0
                                Hans Kremers
                                Hans Kremers
                                Matt
                                Matt
                                John Davies 2
                                John Davies 2
                                • Routenplaner on iPad
                                • New Zealand Routes
                                  Bull Tahr
                                  Bull Tahr
                                  J2FK
                                  J2FK
                                • MyRouteApp (WebPlanner) development Roadmap
                                  Philipp Kühn
                                  Philipp Kühn
                                  6.2k
