  3. Beta Instructions 🍏iOS (Forum)
Scheduled Pinned Locked Moved [App-Beta] The MyRoute-app
42 Posts 25 Posters 1.8k Views 5 Watching
  • Jose Pinheiro 0
    Jose Pinheiro 0
    Jose Pinheiro 0
    Hi.
    I'm trying to test the beta version, but I think that I only get the some old version of MRA, and not the navigation next.
    I've opened the app from the TestFligth, after following the instructions on email.
    Is this the layout of MRA Navigation Next? I can't see the turn-by turn information, and it just look like the old version:
    "So many roads, so little time"
    • Jose Pinheiro 0 Jose Pinheiro 0
      Hi.
      @Jose-Pinheiro-0 This is the correct version. Instead of opening the route, you can click on the "Navigation" icon (most right in the row containing 4 buttons).
      Note: track navigation is not support
      Jose Pinheiro 0 1 Reply Last reply
        @Arjan-de-Vries Klikken op de knop in de mail van TestFlight zou voldoende moeten zijn.
        Arjan de Vries
        Arjan de Vries
        Arjan de Vries
        @Corjan-Meijerink werkt
          Jose Pinheiro 0
          Jose Pinheiro 0
          Jose Pinheiro 0
          wrote on last edited by Jose Pinheiro 0
          @Corjan-Meijerink What I'm doing is:
          1. Search the destination and click on "Generate"
          2. After the route is presented, I choose "Start"
          3. The Navigation starts, but without tur-by-turn information
          I believe I'm doing something wrong, but can't figured out what is it 😞
          Christopher M Kelly 1 Reply Last reply
            @Mart-Hanssen Als de instructies precies worden gevolgd, zou het goed moeten gaan.
            Als je TestFlight hebt geïnstalleerd, ga terug naar de mail die je van TestFlight hebt gehad en klik hier wederom op de knop. Als het goed is, opent TestFlight nu en heb je toegang tot de Beta.
            @Jack-van-Tilburg Bedankt voor de bevestiging!
            Mart Hanssen
            Mart Hanssen
            Mart Hanssen
            @Corjan-Meijerink Het werkt. Probleem lag in de e-mailadressen. Als je een ander e-mailadres gebruikt dan je apple account.
              Christopher M Kelly
              Christopher M Kelly
              Christopher M Kelly
              @Jose-Pinheiro-0 above the 'Generate' button select the right-hand button'Y' shape and then tap 'Generate'
              I ride for work, I work to ride
              • Christopher M Kelly Christopher M Kelly
                Jose Pinheiro 0
                Jose Pinheiro 0
                Jose Pinheiro 0
                @Christopher-M-Kelly Thank you.
                You are right. I'm using the button on the left and it doesn't work, but with the button on right "the Y button" it works. 🙂
                  @Arjan-de-Vries Super!
                    @Jose-Pinheiro-0 That is exactly how it works!
                    @Christopher-M-Kelly Thanks for helping.
                    We want users to be able to still use the original route generator in the Mobile app.
                    • WoFi
                      WoFi
                      WoFi
                      Hello,
                      thank you for the opportunity to take part in the test.
                      My test environment MRA Navigation Next (Beta 3.2.4 - 143) - Iphone 11 (IOS 16.1.2) - Voice output via radio (Bluetooth) - Carplay WLAN
                      During my first test I noticed the following:
                      1. Voice Prompt
                        • is cut off at the end
                        • hides the radio correctly, but does not show it again after the announcement
                      2. Direction indicator (motorway)
                      • "Nehmen Sie d…" is illegible (see image 1)
                      • Announcement follow ... is not displayed - despite several exits before departure (see image 2)
                      1. Skipping a waypoint
                        You did well. The selection "Bestätigen" or via the "Symbol" is in my opinion a little bit small and double. Possibly a back button (jump back one waypoint) would also be useful. Especially when implementing the ability to skip multiple waypoints. The setting "über Start navigieren" is also missing.
                      2. Speed ​​Warning
                        The warning is very sensitive. An adjustable tolerance - 5 km/h in town / 10 km outside town - would make sense for me. Nor does a warning need to be repeated every few seconds.
                      Maybe my comments will help with the development.
                      I'm looking forward to the further developments.
                      Best Regards Wolfgang
                      WoFi Corjan Meijerink 2 Replies Last reply
                      • WoFi WoFi
                        Hello,
                        1. Voice Prompt
                        2. Speed ​​Warning
                        WoFi
                        WoFi
                        WoFi
                        • WoFi WoFi
                          Hello,
                          1. Voice Prompt
                          2. Speed ​​Warning
                          @WoFi Thanks for the feedback, much appreciated!
                          1: Voice guidance will be improved! Other testers have encountered the same behaviour as you.
                          2: Translations need some improvement. We mainly use Dutch / English versions of the app so any language specific issues (such as this) are valuable
                          3: Great suggestion! 🙂
                          4: This would indeed be a good change, it indeed is quite sensitive now.
                          Thanks again for your feedback. We will use it as input for the development!
                          Ad Koppenol 1 Reply Last reply
                            Ad Koppenol
                            Ad Koppenol
                            Ad Koppenol
                            @Corjan-Meijerink said in Beta Instructions 🍏iOS (Forum):
                            • 1: Voice guidance will be improved! Other testers have encountered the same behaviour as you.
                            • MyRoute-app community MyRoute-app community moved this topic from [App-Beta] The MyRoute-app on
                            • MyRoute-app community MyRoute-app community moved this topic from [App-Beta] Suggestions and Discussions on
                            • Evert-Jan 0
                              Evert-Jan 0
                              Evert-Jan 0
                              wrote on last edited by Evert-Jan 0
                              #26
                              • Evert-Jan 0 Evert-Jan 0
                                [[topic:post-is-deleted]]
                                @Evert-Jan-0 Hoi Evert-Jan, het is normaal gesproken onverstandig om je e-mailadres te posten op een openbaar forum. Je verhoogt hiermee het risico op spam enorm. Nu is het Beta MRA Navigation Next deel volgens mij niet (geheel) openbaar, maar het is waarschijnlijk toch handig om het weg te halen en het alleen te communiceren als je via een support ticket contact zoekt met de mensen van MRA.
                                Evert-Jan 0 1 Reply Last reply
                                  Evert-Jan 0
                                  Evert-Jan 0
                                  Evert-Jan 0
                                  @Herko-ter-Horst said in Beta Instructions 🍏iOS (Forum):
                                  Oké, bedankt voor de waarschuwing .
                                  • Ewen Fowler
                                    Ewen Fowler
                                    Ewen Fowler
                                    Hi, I never received an email to download the beta. I am signed up.
                                    • Ewen Fowler Ewen Fowler
                                      @Ewen-Fowler The best thing to do is create a new ticket via MRA Support
                                      • Dikke Wim
                                        Dikke Wim
                                        Dikke Wim
                                        Drie dagen geleden heb ik een MRA Navigation Next (beta) life time gekocht. De aanschaf is bevestigd. Echter ik heb geen email ontvangen met verdere instructies.
                                        Graag hulp. Zaterdag zou ik de navigatie willen gebruiken op een lange motorrit.
                                        Bij voorbaat dank.
                                        • Dikke Wim Dikke Wim
                                          Bij voorbaat dank.
                                          @Wim-Dictus Zoals daar ook staat vermeld worden nieuwe aanmeldingen ongeveer eens per week verwerkt. Dit heb ik zojuist gedaan, je hebt een TestFlight uitnodiging ontvangen 😉
                                          JoukeStroo 1 Reply Last reply
                                          Arjan de Vries
                                          Arjan de Vries
                                          Dikke Wim
                                          Dikke Wim
                                          Siepermann- Ronald
                                          Siepermann- Ronald
                                          Michel van Hagen MRA-Founder
                                          Albert Renting
                                          Albert Renting
                                          Paul 41
                                          Paul 41
                                          Frappawotsit
                                          Frappawotsit
                                          Ad Koppenol
                                          Ad Koppenol
                                          M Gaudion 0
                                          M Gaudion 0
                                          Mart Hanssen
                                          Mart Hanssen
                                          Jose Pinheiro 0
                                          Jose Pinheiro 0
                                          JoukeStroo
                                          JoukeStroo
                                          ron putting
                                          ron putting
                                          Wil van Hulst
                                          Wil van Hulst
                                          Christopher M Kelly
                                          Christopher M Kelly
                                          Ewen Fowler
                                          Ewen Fowler
                                          Evert-Jan 0
                                          Evert-Jan 0
                                          WoFi
                                          WoFi
                                            David 38
                                            David 38
                                          • Download club route folders
                                            Òscar
                                            Òscar
                                          • Passwords
                                            Captain Haddock
                                            Captain Haddock
                                            Ed Lauwerens 0
                                            Ed Lauwerens 0
