  2. Routes & Tracks
  3. Zumo XT routing issue with 1.2
12 Posts 4 Posters 2.8k Views 2 Watching
  • Larry Staynerundefined Offline
    Larry Stayner
    I recently finished a 6 day trip using MRA downloads. I used the 1.2 download and exported my routes to Garmin Drive. Day 1 the route was flawless. Day 2 1.2 would only instruct turns 4 or 4 times on a 400 mile route with many more turns. I found myself doing a U-Turn several times. Day 3 the route was flawless again. Day 4 I had the same issue as Day 2. Day 5, I downloaded the gpx file as a 1.1 to compare how it would route me. My route in 1.2 was still missing a lot of turns where the 1.1 was almost perfect with the exception of two turns at the same location. Day 6 I went with a 1.1 file and it performed perfect. Am I doing something wrong with the 1.2 download that I am getting erratic routing?
    Reinhard-32undefined Hans van de Ven MR.MRAundefined 2 Replies Last reply
    • Larry Staynerundefined Larry Stayner
      Reinhard-32undefined Offline
      Reinhard-32
      @Larry-Stayner-0 If you use the GPX 1.2 version the new calculation at the GarminXT must switched off.
      Kindly regards
      Reinhard
      Montana 700i and Mac
      Larry Staynerundefined 1 Reply Last reply
        Larry Stayner
        @Reinhard-32 I am pretty sure mine is set to no calculation for off route if that is what you mean.
          @Larry-Stayner-0
          Hi @Larry-Stayner-0
          This can have various causes, such as not enough satellite connections (at least 3), how far are you from the starting point of your route, which point have you selected to start, do you start your route inside the garage? With all these examples, the zumo can start calculating and adjust your route
            @Larry-Stayner-0
            Hi @Larry-Stayner-0
            Larry Stayner
            @Hans-van-de-Ven-MRA-Master I was in the Tennessee USA in the country with no interferences. It started right after I left my starting point and continued throughout the ride. I restarted the route several times using the closest entry point. I had recalculation set to manual. What was interesting is that the next day, the route was flawless.
              @Larry-Stayner-0
              Can you share the url off the route that went wrong.
              Make sure it is set public
                @Larry-Stayner-0
                If you are using the gpx 1.2, you must turn off route recalculation on the Zumo XT
                  @Larry-Stayner-0
                  Larry Stayner
                  @Hans-van-de-Ven-MRA-Master https://www.myrouteapp.com/route/open/6501800
                  This is the route that gave me problems.
                  Hans van de Ven MR.MRAundefined sudoleaundefined 2 Replies Last reply
                    @Larry-Stayner-0
                    Hi Larry,
                    I see the following items that can be the reason of the issues.
                    Route made in the OSM map
                    8 routepoints for 600km
                    But I guess that the reason is that there are non viapoints in the route except the start and end.
                    A gpx 1.2 needs viapoints in the route
                      @Larry-Stayner-0
                      Hi Larry,
                      Larry Stayner
                      @Hans-van-de-Ven-MRA-Master Thank you for the information. Since I am currently just a basic member, OSM is my only option. I am weighing the advantages of being a gold member to get the Garmin maps. Actually watching a YouTube video of Serge explaining the differences.
                        sudoleaundefined Offline
                        sudolea
                        wrote on last edited by sudolea
                        @Larry-Stayner-0 said in Zumo XT routing issue with 1.2:
                        Larry, which route was that ? The day 2 or day 4 ? Could be interesting to compare this one with one of your non-problematic routes ?
                        (edited)
                        • sudoleaundefined sudolea
                          (edited)
                          Larry Stayner
                          @sudolea That was day 2. Unfortunately, I already added a bunch more waypoints to day 4 when we got to our destination.
                          Reinhard-32
                          sudoleaundefined
                          sudolea
                          Larry Stayner
                            Axel Härtlundefined
                            Axel Härtl
                            2.4k
                          • seizoen afsluitingen
                          • Poi's per rit op meerdaagse reizen
                            Jan Weerheimundefined
                            Jan Weerheim
                          • Doe ik iets verkeerd of...
                            Michel 71 0undefined
                            Michel 71 0
