  2. Routes & Tracks
  3. Suggestion/Request - Exit without saving
routeplanner
13 Posts 5 Posters 4.1k Views 1 Watching
  • Carlo Baronchelli Offline
    Carlo Baronchelli
    wrote on last edited by Carlo Baronchelli
    I would really appreciate being able to choose whether to save the route I am editing or to exit without saving; or, in alternatively, I would like that, from the moment I open a path to modify it, a backup copy was created so that the original path can be recovered in case of serious 'messes' committed during the modification.
    • Carlo Baronchelli Carlo Baronchelli
      Jack van Tilburg Offline
      Jack van Tilburg
      @Carlo-Baronchelli said in Suggestion/Request - Exit without saving:
      I understand that suggestion.
      In that case I make a copy of a route before I edit it.
      Carlo Baronchelli 1 Reply Last reply
        Carlo Baronchelli
        @Jack-van-Tilburg
        Yes, thank you. I also sometimes make this way.
        But it's not very comfortable...
        And sometimes I forget ...
        Drabslab 1 Reply Last reply
          @Jack-van-Tilburg
          Drabslab Offline
          Drabslab Offline
          I am glad I am not alone 🙂
          You may point to a shortcoming of the routeplanner here. All changes are immediately stored in the "official" version on the MRA server.
          It could perhaps be better that route editing is done on a temporary version (although still stored on the server) and that it requires an active intervention (save/save as button) of the user to put the changes also in the official version.
          Mopetenpit Jack van Tilburg 2 Replies Last reply
          • Drabslab Drabslab
            Mopetenpit Offline
            Mopetenpit Offline
            Mopetenpit
            @Drabslab
            110 % approval 👍
            • Mopetenpit Mopetenpit
              @Drabslab
              110 % approval 👍
              Carlo Baronchelli
              @Drabslab
              • Drabslab Drabslab
                Jack van Tilburg
                @Drabslab
                Whaha @Drabslab, 😁
                I do read in your posts that you were/are active in the IT world. And I think you sometimes use your experiences here on the forum to contribute to the help to fellow users.
                As an IT person you know that you are not allowed to work on an item until you have secured a (verified) backup? 😇
                  @Drabslab
                  Whaha @Drabslab, 😁
                  Drabslab Offline
                  Drabslab Offline
                  @Jack-van-Tilburg said in Suggestion/Request - Exit without saving:
                  Yes, I try to help a bit, possibly to the desperation of MRA folks when I start complaining about their percieved "hobby club" approach 🙂 🙂 🙂
                  However, I try to keep it fairly low key avoiding the IT slang, or references to development models and stuff like that.
                  But you are a piece of the same cloth, ain't you Jack?
                  • Drabslab Drabslab
                    Jack van Tilburg
                    @Drabslab
                    • Don Stauffer Offline
                      Don Stauffer
                      I've had similar thoughts, but I have finally developed the habit of 'copy, then edit'. After a bit it's become second nature.
                      • Jack van Tilburg Offline
                        Jack van Tilburg
                        There is of course another very big advantage in copying the route before you modify it.
                        If you are going to edit the copy, you can add the original route to the map via the <Routes> menu in the left column.
                        In this way you can keep the adjustments well in view and bring them back to original if necessary.
                          Drabslab Offline
                          Drabslab Offline
                          Very correct and this c(sh)ould be added to the temporary version way of working. You see the original version on screen + the modifications in "track changes lay-out" (another color for instance). And clicking the save button incorporates the changes in the original route.
                          • Drabslab Drabslab
                            Jack van Tilburg
                            @Drabslab said in Suggestion/Request - Exit without saving:
                            Nonsense. In doing so, you cannot go back to the original version. That will go wrong with many users!
                            Don Stauffer
                            Don Stauffer
                            Mopetenpit
                            Mopetenpit
                            Jack van Tilburg
                            Jack van Tilburg
                            Carlo Baronchelli
                            Carlo Baronchelli
                              Sytze van der Laan
                              Sytze van der Laan
                              Bruno 7
                              Bruno 7
                              George Shanks 0
                              George Shanks 0
                              Huibertus
                              Huibertus
                            • Hi again...Please help
                              ConiKost
                              ConiKost
                              9.2k
