  3. Forcing the Zumo XT to go down a road it doesn't recognise
6 Posts 3 Posters 1.5k Views 1 Watching
  • Rob Wilkie
    Rob Wilkie
    Rob Wilkie
    So - I am planning a route through a forest and the start of the road I want to travel on (which I know is open) is not recognised on the HERE map. It IS recognised on Open StreetMap and TomTom Map.
    I put a shaping point where I know the road starts and another half a mile down the road. Using OSM or TT the route works fine but use Here and the route takes a massive detour to get to the second shaping point. Download to my Zumo and it also takes a massive detour.
    I can get round the issue on MRA by selecting SKIP on the second waypoint and MRA straight lines between the two. But download to the Zumo and the massive detour is still there ON THE ROUTE - THE TRACK IS FINE.
    I prefer to navigate using routes as I include via points for all the places I want to stop and like being able to see how far or how long to the next via point. Can anyone advise what I need to do to get the Zumo to follow the route I want and effectively straight line between points where it thinks a road doesn't exist?
    I thought about turning off unpaved roads in the Avoidances section in Route Preferences but that didn't solve it and I would prefer not to have that selected as I really don't want the Zumo thinking it can really send me off to the wilds to save a minute or two!
    • Rob Wilkie Rob Wilkie
      @Rob-Wilkie
      Hi Rob, I guess the road is not on the Here-map, or the road is broken. Put a viapoint at the begin and end of that road and drive
      Rob Wilkie 1 Reply Last reply
        @Rob-Wilkie
        Rob Wilkie
        Rob Wilkie
        Rob Wilkie
        @Hans-van-de-Ven-MRA-Master
        Thanks Hans - this is what it looks like on the HERE map
        Same road on Michelin with OSM chosen
        I've ridden this road before and know it will so its not an issue. But was hoping to find a way for other occasions. But if it can't be done them so be it
        stuart marritt 1 Reply Last reply
          stuart marritt
          stuart marritt
          stuart marritt
          I had this same issue see my replies to this post https://forum.myrouteapp.com/topic/958/mapping-errors/6
          And also on here
          https://www.zumouserforums.co.uk/viewtopic.php?t=1869
          • stuart marritt stuart marritt
            And also on here
            Rob Wilkie
            Rob Wilkie
            Rob Wilkie
            wrote on last edited by Rob Wilkie
            @stuart-marritt Thanks Stuart. Looks very similar. I don’t however use BaseCamp at all. I do my planning on MYR and then save as GPX 1.1 which I load straight onto the XT.
            Just decided to see what happens if I upload as a GPX 1.2. Thats after using the skip waypoint option to straight line across the “broken” road and it works fine. So that may be the answer if you can cope with not having any of the shaping points included.
              stuart marritt
              stuart marritt
              stuart marritt
              @Rob-Wilkie same here but the issue is to do with the way MRA uses avoidances
              Namely State Highways!
              Turning this off in basecamp allows you down the road yet you have no option to take it off in MRA
              stuart marritt
              stuart marritt
              Rob Wilkie
              Rob Wilkie
                TomOnTour
                TomOnTour
              • Newsletter optimisation
              • route aanklikken in overzichtskaart
              • Trekking tool: sun/shade
              • How can I change colours in the route overview?
                Kudee
                Kudee
              • Skip feature in the MRA Classic
                TomOnTour
                TomOnTour
