  3. Garmin XT
Garmin XT
2 Posts 2 Posters 478 Views
  • Matti Mäkinen
    Matti Mäkinen
    Matti Mäkinen
    Garmin XT is not in the export device list? Why is that?
    • Matti Mäkinen Matti Mäkinen
      Steve Lynch
      Steve Lynch
      Steve Lynch
      @Matti-Mäkinen
      Presuming you are using a PC, and using the connector you should use Garmin GPX1.1 or Garmin GPX1.2
      GPX1.2 Will only show you the Via Points, Hands in MRA, Flags on the Zumo XT, but will shape the route based on the Shaping Points you have used.
      GPX1.1 will show you Via Points and Shaping Points.
      Shaping Points are Balloon icons in MRA, Blue Dot on the XT.
      Steve Lynch
      Steve Lynch
      Matti Mäkinen
      Matti Mäkinen
      • Route wordt afgesneden
        Wim Hompes
        Wim Hompes
      • Problem with HERE, getting the route correct ??
      • Map blurred when editing POIs
      • Maps Michelin
        Jacob Waterweg
        Jacob Waterweg
      • OSM Routing with MRA
      • App failed to start; reinstall locked me out!
        Anonymouse
        Anonymouse
      • Knop rondrit
