  3. Sygic works with GPX import again
11 Posts 7 Posters 9.7k Views 3 Watching
  • Reinhard-32 Reinhard-32
    Re: Sygic Connectivity Issue
    With the last update sygic added the option for route import in the gpx format. On my IPad I exported a route in gpx 1.1 format and shared the route to sygic.
    @reinhard-32
    Thanks @Reinhard-32
    • Patrick Bijnsdorp
      Patrick Bijnsdorp
      Patrick Bijnsdorp
      How did you import the file into Sygic if you don’t mind me asking.
      • Patrick Bijnsdorp Patrick Bijnsdorp
        Reinhard-32
        Reinhard-32
        Reinhard-32
        @patrick-bijnsdorp
        Steps at my IPhone / I PAD
        1. Within MRA safe your route as gpx 1.1 file on your phone.
        2. Navigate with your file manager to this file in the download folder on your phone.
        3. Klick the file and send/share it to sygic.
        4. Sygic will start and shows the route.
        Kindly regards
        Reinhard
        Montana 700i and Mac
        MotoCon Patrick Bijnsdorp Herko ter Horst Mopetenpit 4 Replies Last reply
          @patrick-bijnsdorp
          I was ready to say it works for Android also. But it doesn't. No matter in what format I save the gpx, after opening it Sygic it calculates the fastest way from startpoint to endoint, and no shaping points are visible.
            @patrick-bijnsdorp
            Patrick Bijnsdorp
            Patrick Bijnsdorp
            Patrick Bijnsdorp
            @reinhard-32 thnx! It does work really easy.
              @patrick-bijnsdorp
              @reinhard-32 said in Sygic works with GPX import again:
              @patrick-bijnsdorp
              Step 2 and 3 are not needed. When saving the route as GPX 1.1, you can select Sygic directly, instead of saving to a file/download folder.
                @patrick-bijnsdorp
                Mopetenpit
                Mopetenpit
                Mopetenpit
                @reinhard-32
                When I do the import on my iPhone (current version), I only get the start and end points on Sygic - i.e. one track. Can I also "have" the route points? Or is the premium version necessary for this?
                Peter
                • Mopetenpit Mopetenpit
                  @reinhard-32
                  Peter
                  Reinhard-32
                  Reinhard-32
                  Reinhard-32
                  @mopetenpit The same here. I have made a test. I send a Roundtrip with at least 40 waypoints in different gpx formats from MRA to Sygic. As a result the routes in Sygic was completely visible but contained only 2 waypoints, the first and the last waypoint and nothing between. When you export this route from Sygic and import this in MRA I found a little route between the first an the last point.
                  I use Sygic for testing and not on a regular basis.
                  Kindly regards
                  Reinhard
                  Mopetenpit 1 Reply Last reply
                    Mopetenpit
                    Mopetenpit
                    Mopetenpit
                    @reinhard-32
                    Danke!
                    • Massimo q
                      Massimo q
                      Massimo q
                      I too have tried in every way to import a route created with MRA into Sygic. The GPX 1.1 file opened in Sygic contains only the starting and ending point, without waypoints, and is completely useless. The only way to create a route and import it into Sygic now seems to be using the web application maps.sygic.com. If there is no solution I think I will delete Sygic from my iPhone 12
                      Mopetenpit
                      Mopetenpit
                      Reinhard-32
                      Reinhard-32
                      Massimo q
                      Massimo q
                      Patrick Bijnsdorp
                      Patrick Bijnsdorp
                        Anonymouse
                        Anonymouse
                      • Move a GPS point on the map
                      • Route Opacity Viewing Existing Routes in Library
                      • MyRouteApp on the Tracer 9 GT+ Display. Works! :)
                      • Route leads straight to endpoint
                        Rolf Engelsman
                        Rolf Engelsman
                      • eCharger and Range
                        John Matthews 0
                        John Matthews 0
