  3. Alternative routes navigation app
14 Posts 4 Posters 2.2k Views 2 Watching
  • Arjan de Vriesundefined Offline
    Arjan de Vries
    Hi all
    My navigation app loads my route perfectly.
    If navigates well. But at a lot of crossroads he gives alternative routes. Is there an option to turn this off?
    Con Hennekensundefined Nick Carthewundefined Hans van de Ven MR.MRAundefined 3 Replies Last reply
    • Arjan de Vriesundefined Arjan de Vries
      Hi all
      @arjan-de-vries, Which navigation app are you using?
      Arjan de Vriesundefined 1 Reply Last reply
        Hi all
        @arjan-de-vries As far as I know, no navigation device offers alternative routes while navigating.
          Arjan de Vries
          @con-hennekens navigation from mra
            Hi all
            @arjan-de-vries
            Can you share a screenshot of those alternative routes?
              @nick-carthew said in Alternative routes navigation app:
              I have never seen alternative routes in MRA Navigation.
              It would not make any sense, besides A to B navigation.
              A screenshot would be nice indeed!
                @con-hennekens My guess is that the app didn’t offer alternative routes. The track lines might have been visible at crossroads because the app was trying to reroute due to inaccurate positioning of route points.
                  Arjan de Vries
                  @nick-carthew perhaps. but the zumo xt has no problem with the road!
                    Arjan de Vries
                    we did not see alternative roads but what we often did see was that the Zumo xt followed the route and the navigation app decided to go the other way. See pics.!IMG_4837.jpg IMG_4835.jpg
                      @arjan-de-vries Thanks for the screenshot. The map used in the XT is a different version to the map that MRA Navigation uses. I suspect that adding a few more route points would solve the problem. Can you share your route here please then I or others can give you advice for future route planning.
                        Arjan de Vries
                        @nick-carthew Good tip!
                        Here is a link to the route:
                        https://www.myrouteapp.com/nl/social/route/5945187?mode=share
                        Nick Carthewundefined 2 Replies Last reply
                          @arjan-de-vries Thanks for sharing your route. From what I understand, the Garmin XT is quite particular about the position of route points. You have to place them accurately on the road. Several of the route points are not on the road.
                          55BC20A0-E65C-458E-97A4-E894CC1D6B86.png B4F4FBEF-4E08-4986-A189-173E5971FDF0.png 654971ED-63A3-49DB-95E1-D9269B0F9567.png 23AC268C-610A-4161-A8F2-D3402296F9CD.png C52B4AD4-03A0-461E-9A9E-C813587AF2C1.png 39922F37-7024-4F3D-8927-288F8764F9AD.png
                            @arjan-de-vries It is also advisable to not place route point too close to junctions, roundabouts and viaducts. The reason for this is to allow for any inaccuracies while the roads were being mapped and the accuracy of the satellite signal when you use the route. Sometimes it can be 20m out and this could send you up a side road and then tell you to turn around.
                            844C73A0-FD18-4198-8926-2EFC2FBC1428.png 34BB9093-0931-4073-A40C-F166D0B8B5F2.png
                              Arjan de Vries
                              thank you all
                              Arjan de Vries
                                Massimo Cardoneundefined
                                Massimo Cardone
                                2.6k
                                Axel Härtlundefined
                                Axel Härtl
                                Aiello antoninoundefined
                                2.9k
                                Jan Weerheimundefined
                                Jan Weerheim
                              • CarPlay says that I need a subscription
                              • Doe ik iets verkeerd of...
                                Michel 71 0undefined
                                Michel 71 0
