  3. Navigate Via Start
Navigate Via Start
5 Posts 3 Posters 843 Views 1 Watching
  • Roadglider59undefined Offline
    Roadglider59
    Can anyone explain exactly what the "Navigate Via Start" option does on the iPhone version of MyRoute App Navigator?
    • Roadglider59undefined Roadglider59
      @james-stewart-1
      Hi @James-Stewart-1 , For example, that you navigate from your home address to the starting point of the route (If the starting point is elsewhere than where you are).
        Roadglider59
        The Android version has an option called "Navigation departure point" which works well. You can select from three options. Is there anything similar to this in the iPhone version or do you have to skip waypoints when you're in the middle of a route?
          @james-stewart-1 said in Navigate Via Start:
          Hi @James-Stewart-1 No, the ios version of the app doesn't have the Navigate Departure Point option and yes, there is an option to Skip waypoints.
            Roadglider59
            wrote on last edited by Roadglider59
            Thanks for the input. I built a route around my current location and tested the options. They seem to work similar, but are worded differently. Testing definitely was the best way to figure this out. I have one issue with the way the Android and IOS versions of the app navigate. The app should navigate to the closest point in the direction that you are going. For instance, I placed a point closest to my location in the opposite direction of my route and the system wanted to double back in the opposite direction and then move forward. In my opinion, the app should alway navigate to the closest point with the higher number.
            Roadglider59
            • Segmentation
              Lenny Oundefined
              Lenny O
              Big Al 1undefined
              Big Al 1
              RetiredWingManundefined
            • Onbekende fout, 3 problemen
              Klompenmaker1undefined
              Klompenmaker1
              Thomas Neumeyerundefined
              Thomas Neumeyer
              1.7k
