  4. Travel time discrepancies
26 Posts 6 Posters 11.1k Views 4 Watching
    @Steve-Jarrell said in Travel time discrepancies:
    Unless someone can show me why there are important advantages to using the HERE maps as the default I'm going to make the OSM maps my default
    The biggest advantage to use HERE maps for planning is the least chance for the planner map to be different than the navigation map. The advice is to plan your route on map that is ost equal to the one you navigate with. For MRA Navigation that is HERE, as is for Garmin devices. There are many differences in maps between OSM and HERE, especially in rural mountenesque areas.
    the bug that causes the following dialog to appear when I switch to the OSM map or import a track into it even though I have my driving mode set to "Driving"
    I am not aware of a driving mode called "driving". I only get this message when I switch from HERE or TomTom to OSM while I have "Motorbike" selected as driving mode.
    Steve Jarrell Offline
    Steve Jarrell
    @Con-Hennekens You are right. My mistake. It's called "Car" so I'm not set on Motorcycle, but I still get the message every time I switch to OSM. What driving mode are you using in your profile?
    Thanks!
    Steve Jarrell
    Western North Carolina US
    2025 BMW R1300GS
    2025 Can-Am Spyder
    DMD T865-X 8" Tablet
    Garmin XT3
    BertM 1 Reply Last reply
      Steve Jarrell
      @Con-Hennekens I overlooked the first part of your post. Thanks for the detailed explanation!
      Steve
      Steve Jarrell
      2025 BMW R1300GS
      2025 Can-Am Spyder
      Garmin XT3
      • Steve Jarrell Steve Jarrell
        Thanks!
        BertM Offline
        BertM Offline
        @Steve-Jarrell
        When i open de route you linked in a previous post the profile is set to motorcycle…
        BertM Steve Jarrell 2 Replies Last reply
        • BertM BertM
          @Steve-Jarrell
          BertM Offline
          BertM Offline
          @BertM ![alt text](IMG_0486.jpeg image url)
          • BertM BertM
            @Steve-Jarrell
            Steve Jarrell
            #25
            @BertM Yes, I've changed it back and forth several time experimenting trying to figure out what's going on.
            If you look at my previous post you'll see where I took a screenshot of my profile setting set to "Car' at the exact same time that the error message is appearing.
            I even thought that perhaps MRA considered the routing mode when the route was created from the track and then ignored it from then on, however I created the route from scratch by importing a .gpx file with the mode set to Car, and as soon as I did I got the error message.
            Thanks for the response!
            Steve Jarrell
            2025 BMW R1300GS
            2025 Can-Am Spyder
            Garmin XT3
              It's specifically the road after waypoint 26 that gives way longer estimates than other map sources. It's based on the realistic travel time HERE tracks for that section and my guess is that their data on that is wrong.
              Either incorrect speed limit or some anomalies in their realistic travel time estimation
              Steve Jarrell
              @Corjan-Meijerink After riding the route last Wednesday it is possible the HERE map is using information about the roads when they were really torn up after Hurricane Helene at the end of last year as some of them were still in pretty bad shape when we rode them and you could see where one lane the road had been washed completely out.
              If the HERE map is using data from late last year it is likely that at that time their estimation of the time that it would take to ride this route would be accurate. Perhaps a future map update will resolve the issue. That's a very plausible explanation.
              Thanks! I don't like mysteries, and I'll consider this one solved! 🙂
              Steve Jarrell
              2025 BMW R1300GS
              2025 Can-Am Spyder
              Garmin XT3
              Steve Jarrell
              Steve Jarrell
              martin-phogel.de
              martin-phogel.de
              • Welke instelling
                Pim van Dongen
                Pim van Dongen
              • Steeds maar weer centreren
                Pim van Dongen
                Pim van Dongen
              • Ability to change units as your navigating
                Kev Parry
                Kev Parry
              • Suggestion about making routes visible in a folder
              • Automatic setting for units
              • scherm bevrirzing
