  4. MRA next is very buggy on my Android Auto
29 Posts 11 Posters 16.6k Views 5 Watching
  • Mzokk Mzokk
    @Léon-Hassing 71ae7e0d-888c-43f9-9ef7-b2abd9582c33-image.png last August
    This is a photo of me testing an earlier iteration of the App against my Garmin Zumo XT. The last two versions of the app. I'm now on 4.3.4 -375 have worked perfectly for me on my Africa Twin and VW ID3
    However, I still think that using Android Auto or Apple Carplay could add levels of troubleshooting if you are having problems. The head unit, the connection (wired or Wifi) and the phone (particularly AA or CP settings) or competing apps (Bluetooth) could all lead to issues that may not be connected to the app that you are using.
    The two that I have encountered over the past year and a half of experimenting with MRA and OSMand are. The data cable not streaming enough data. This was cured by purchasing a high data transfer up to 10 Gbps Amazon Basics cable (about £7) I think. My newest phone glitching when it became charged to 100% and was switching off Android Auto. This was a setting in Android 14 OS which flashed a message on screen that the phone had reached 100% and simultaneously switched off AA. That took some googling to work out and switch off in the Android settings.
    Up to now I've continued to use my Garmin Zumo XT as my Primary navigation device. Now however, the latest version of the app is so good for me I think from now on I will use it for primary navigation with the Zumo as a backup. Not least because I can control the app with the Honda bar buttons which I can't do with the Zumo.
    Gary Coates
    Gary Coates
    Gary Coates
    @Mzokk Thanks for this post. It's helps a lot to know someone else is already having success. I'm trying to do exactly the same as you, make the app my primary navigation and relegate my BMW sat nav to backup.
    • Léon Hassing
      Léon Hassing
      Léon Hassing
      wrote on last edited by Léon Hassing
      #22
      Today I tested the new version of MRA next (4.3.4-377) with AA on my Chigee AIO-5 for BMW (with latest firmware) connected with Pixel 8 phone with android 15. I also read on this forum about zoom in on your phone for a better view of the directions on the map and clearing the cache when GPS was stuck.
      The start of the test was promising. The zoom level was ok, the directions were given correctly. Nice. I planned some stops where I wanted to turn off the engine. After the first stop I started navigation, but the arrow was stuck at the position where I had stopped. After a km of driving the arrow was still on that location. I stopped for clearing the cache and restart MRA. All seemed OK since the arrow was now on the correct and current location. But it didn't move after I started to drive again. I tried it several times, but the behavior was the same. In the end I could still hear the directions and see them on the screen, but the arrow and map remained at the last location. So while the navigation gave the correct instructions the map and arrow didn't move. Also the track that I recorded was only correct at the beginning of the trip and had straight lines between the spots where I cleared the cache.
      Conclusion for me: MRA on AA is still not working as I would expect. I hope these issues will be resolved before the new riding season starts, otherwise I think I will start using the TT GO Navigation. I also hope the developers can use my tests and fix this problem, because I definitely would like to use MRA on AA.
      Mzokk Corjan Meijerink 2 Replies Last reply
      • Léon Hassing Léon Hassing
        @Léon-Hassing said in MRA next is very buggy on my Android Auto:
        I'm also using MRA next (4.3.4-377) with a Motorola Edge Neo 40 (Android 14) and occasionally a Motorola G7 (Android 10). I use routes to navigate not tracks (I haven't tried route navigation yet. But I haven't had any issues recently using wired AA on a Honda Africa twin (executing a planned route) or wireless AA in a VW iD3 (mainly point to point navigation). This is a report on the software I posted on another forum on 16 Dec. 2024
        I carried out a test yesterday on 4.3.4-375. The route was only 85 miles with 3 via points and 24 waypoints in total including the Start and Finish. I plugged my phone into the USB port on my Africa Twin and used Android Auto. Selecting the route on the AA screen using the bar buttons, navigating the route itself, restarting the route after stopping for coffee (On AA) and automatically skipping waypoints on the way home all worked perfectly and the route stopped automatically after passing the finish waypoint. With the phone plugged into the bike for AA the charge went from 63% to 100% with no noticeable phone heating despite the phone being transported in a small padded camera bag. On the Honda you can flip between AA and the bike information screen, I flipped back and forward several times and this didn't trip the app. I haven't tested routing via a track yet. All in all, the app is massively improved from its first iteration 18 months ago and easily as usable as my Garmin Zumo XT. The Honda takes a while to sort itself out with screen booting and connecting to the phone, (obviously this is not an issue with the app.) So I've been connecting the phone and starting the Honda screen while putting on my Helmet and gloves. Very slick and impressive.
        So it must be difficult for the developers when one set of hardware produces faultless results and another may not. I'm sure they would be interested in you raising a ticket to see where the issues might be.
        Léon Hassing 1 Reply Last reply
        • Mzokk Mzokk
          Léon Hassing
          Léon Hassing
          Léon Hassing
          @Mzokk said in MRA next is very buggy on my Android Auto:
          @Mzokk Thank you for your reply. I have raised a ticket.
            @Léon-Hassing this issue is resolved! Update is currently in beta expecting a public release of this fix next week 🙂
            Long story short: hanging position indicator in Android Auto is fixed 🎉
            Léon Hassing 2 Replies Last reply
              Léon Hassing
              Léon Hassing
              Léon Hassing
              @Corjan-Meijerink said in MRA next is very buggy on my Android Auto:
              Wow, very good news. 👏 I can't wait 😆
                Léon Hassing
                Léon Hassing
                Léon Hassing
                I can confirm that the issue regarding the hanging position indicator in Android Auto is fixed in version 4.3.5 - 378. I tested it last weekend and it is working as you would expect.
                  @Léon-Hassing awesome!
                    Léon Hassing
                    Léon Hassing
                    Léon Hassing
                    @Corjan-Meijerink I'm afraid the fix for the hanging position indicator in Android Auto that was fixed in version 4.3.5 - 378 is reverted / occurring again in the latest version 4.3.8 - 386. Could you please look into this?
                    Léon Hassing
                    Léon Hassing
                    OGRIII
                    OGRIII
                    Garry Davis
                    Garry Davis
                    PieterG
                    PieterG
                    Jan 50
                    Jan 50
                    Gary Coates
                    Gary Coates
                    Robert Gronewold
                    Robert Gronewold
                      Alderweireld Rudi 0
                      Alderweireld Rudi 0
                    • Weather as a service
                      Andy Smith 5
                      Andy Smith 5
                    • Lane view in Android Auto
                      denWINNE
                      denWINNE
