  3. Wonderwheel zoom function Chigee
9 Posts 8 Posters 1.5k Views 1 Watching
  • Brian Sprott
    Brian Sprott
    Brian Sprott
    MRA Navigation Next support for Chigee AIO-5 and BMW Multi-controller
    Could anyone please confirm if the wonder wheel now operates the zoom in /out function on the Next map on the Chigee? Thanks
    Marius Gross 1 Reply Last reply
    • Brian Sprott Brian Sprott
      Marius Gross
      Marius Gross
      Marius Gross
      @Brian-Sprott said in Wonderwheel zoom function Chigee:
      Als Ergänzung zu der Frage von Brian.. Wenn es funktioniert, wäre es möglich, ein kurzes Video zu posten, wo genau gesehen werden kann, wie über das "Wonderwheel" die Ansteuerung funktioniert? Danke.
      • Chudy
        Chudy
        Chudy
        I want to ask about this same.
        • Lluis Arasanz
          Hola,
          Tengo un amigo que usa Chigee AIO6 en moto BMW y la Wonderwheel le funciona perfectamente para todas las funciones, asi que a día de hoy el soporte es total.
          I have a friend who uses Chigee AIO 6 on his BMW motorcycle and the Wonderwheel works perfectly for all functions, so as of today, the support is complete.
          • BMW F750GS
          Òscar 1 Reply Last reply
          • Lluis Arasanz Lluis Arasanz
            Hola,
            @Lluis-Arasanz That's me. It works 100%. There's nothing better on the market.
            • https://t.me/MRa_by_b0hd1
            • YouTube: @demco17
            Christian Feurstein 1 Reply Last reply
            • Òscar Òscar
              Christian Feurstein
              Christian Feurstein
              Christian Feurstein
              @b0hd1 can you give a brief description of how the zoom function is working when using the wonderwheel? Simply turning the wheel won´t be enough is it?
              • Christian Feurstein Christian Feurstein
                @Christian-Feurstein There are two selectors (+ and -) on the screen. Position yourself over them by rotating the wonderwheel and click to the right. It's very simple.
                • YouTube: @demco17
                • Leike Lodiers
                  The wonder wheel doesn't zoom on de Chigee it scrolls through the menu buttons. So you need to select the + or - to scroll. Maybe in the future this option will be available because i think you zoom more then you need the menu buttons every time.
                  • Dae 0
                    Dae 0
                    Dae 0
                    wrote on last edited by Dae 0
                    The Chigee never sends the signals to apps about the wonder wheel movement, so neither MRA nor any other app can react to you twisting the wheel. I’m not sure about Android Auto, but that’s how CarPlay works. It only communicates to the apps which buttons you’ve pressed/touched on the CarPlay screen itself.
                    The Chigee uses the wheel to move the selection box to the button you want to “press”, then nudging the wheel “touches” the highlighted button. All MRA sees is that you “touched” that onscreen button. It never sees that you rotated the wheel.
                    Brian Sprott
                    Brian Sprott
                    Dae 0
                    Dae 0
                    Christian Feurstein
                    Christian Feurstein
                    Chudy
                    Chudy
                    Marius Gross
                    Marius Gross
                      TomOnTour
                      TomOnTour
                    • Android Auto TFT
                    • Select friends problem
                      stuart marritt
                      stuart marritt
                    • Download club route folders
                      Solo1138
                      Solo1138
