  4. V4.2.0 (320) Test
V4.2.0 (320) Test
9 Posts 2 Posters 171 Views 3 Watching
    @Corjan-Meijerink : Hey,
    I'd rather write something here for the test instead of an announcement sorry, it was too eager!!! (Can be deleted under announcement)
    Offline Test: V4.2.0 (320)
    1.) After the update and then without Internet, I could not set a WP in the +MRA planning, first had to go online briefly then offline again then it went ... ,
    2.) The planning goes well with the +MRA planning, but there are problems when saving, apparently only one file can be saved offline so without Internet in the download. When further planning a second route, the previously planned one is overwritten regardless of the name of the file.
    3.) Offline routes with the route created under +MRA planning is not possible, the following notes come to me ...
    It should work without internet now, shouldn't it?
      Hey, an addendum:
      After a map update, the offline navigation is now error-free again!
        Hey, an addendum:
        Addendum Offline with Track:
        1.) File name the same but not recognizable what is the route of it now and what is the track s. to the picture to 1.)
        2.) However, the track navigation still does not work, something is stuck ... selected as a route it seems to work.
        zu1.)
        zu 2.)
          zu1.)
          zu 2.)
          Addendum file will be overwritten:
          File route / track are overwritten separately but with each new planning and thus the previously planned route and track are gone, only the last one remains available.
            Addendum to save
            If you're online, it doesn't seem to be overwritten 👋❓
              Addendum to save
              Addendum Offline Setting and + MRA Planning
              You don't have a network and still want to plan something, but there is still such a small / big obstacle ...
              The user is surprised with the planner under + MRA plan that you cannot set a WP, for this you have to cumbersomely switch to the navigation setting and set it to offline.
              Only then can WP also be set, which overwhelms some and should be easier.
                Further test, calling up a route via the menu, which was previously created with +MRA schedule when you are offline.
                Further test everything offline:
                • Download folder
                The upper one is probably the route, unfortunately the difference between route and track is not visible. 🤔
                After selecting the route, from the download, that's possible, but then it jumps into the ges. Menu s. Picture 1, back what is not optimal would be better to select "Start / Edit" s. Picture 2
                After that, the selection is to navigate with the route or the track.
                • Route goes!
                • Unfortunately, track doesn't work?
                Picture 1 Then tap in the upper left corner 🤔
                Picture 2 make a selection wants to navigate so 2.)
                Picture 3 wants to navigate but with the route
                Picture 4 Route goes
                • Hubert Thoring Hubert Thoring referenced this topic on
                  Thanks for the feedback.
                  A new beta will be released soon (321) and that will be released to the public.
                  Some issues you mentioned are solved in that version.
                    @Corjan-Meijerink : Dankeschön 🙏
