  4. Fuel recommendations
7 Posts 3 Posters 97 Views 3 Watching
  • UltraStar
    UltraStar
    UltraStar
    I just came back from a long trip. I was watching the fuel recommendation in the left top corner of the display, and it is totally useless, unless I am doing something wrong.
    I was traveling on the interstate (US) and the fuel icon showed the gas station in about 200 mi while I was by the exit to the gas station. This was happening in many cases. The funny thing is, the distance was changing between some odd numbers (10 mi, 18 mi, 220 mi, etc.) and was getting longer often while I was driving.
    I do not know if this is connected to only some gas stations participating in the program, or I just set up something wrong in the application.
    Please help!
    Stefan Hummelink Corjan Meijerink 2 Replies Last reply
    • UltraStar UltraStar
      Please help!
      @UltraStar This function used to work flawless before some of the latest updates. The Devs have been notified about it, not sure when they'll be able to look into it. πŸ˜„
      UltraStar 1 Reply Last reply
        Please help!
        @UltraStar Thanks for pointing this out! It has indeed brought to our attention and I'm aiming to get the functionality improve before the next update πŸ™‚
        UltraStar 2 Replies Last reply
          UltraStar
          UltraStar
          UltraStar
          @Stefan-Hummelink Thank you Stefan.
            UltraStar
            UltraStar
            UltraStar
            @Corjan-Meijerink Thank you Corjan. I am sure you will fix it. This is not the most important issue you are working on at the time, but that is good you are aware of it. Thanks again.
              UltraStar
              UltraStar
              UltraStar
              @Corjan-Meijerink Thank you for fixing the issue with the fuel recommendations. The new icon on the map it is additional plus. πŸ™‚
              Also, I do not know if this is a good place to mention, my battery usage (on the iPhone 11P with a generic wireless charger) improved. I am traveling a lot lately, and the 350 miles ride takes only about 25 to 30% of the battery. I do not know if this is a fluke, I did not change any hardware, or something was done in Here maps to improve the issue.
                @UltraStar They are continuously improving so to say but the real significant improvement is yet to be made!
                UltraStar
                UltraStar
                • Log in
                  Rod Sydenham
                  Rod Sydenham
                • Restriction on scenic length?
                  Jeroen ekkel c
                  Jeroen ekkel c
                • AI pricing is too high
                • Segment function with the HERE map
                  Emanuele 5
                  Emanuele 5
                • Library Structure
                • Nieuw start punt maar krijg de route niet hernummerd in logische volgorde
                  Juudje39
                  Juudje39
                  Andy Beviere
                  Andy Beviere
                  1.7k
