  4. In app route/track multiple options/alternatives not working
7 Posts 4 Posters 92 Views 3 Watching
  • Edwin_M
    Edwin_M
    Edwin_M
    I thought that before when selecting a destination, it was possible to have alternatives calculated if you press the windyness option again.
    For me that options appears to have stopped working, the route stays the same no matter how much I press.
    Press1
    Press2
    Press3
    Same for every option in latest beta
    • Edwin_M Edwin_M
      Press1
      Press2
      Press3
      @Edwin_M On my iPhone, that works just fine. Are you using the latest version? Build 286? Maybe try force close the app and give it another go?
        @Rob-Verhoeff on my Android phone it works fine as well
        Edwin_M 1 Reply Last reply
          Edwin_M
          Edwin_M
          Edwin_M
          strange
          I must close then app frequently due to no map.
          That doesn't fix it
          Just tested again. Not working
          • Edwin_M Edwin_M
            strange
            That doesn't fix it
            Edwin_M
            Edwin_M
            Edwin_M
            Retested today and it is working again.
            Strange, as the version has not changed
              I just found that the third windiness option ALWAYS gives the same route as the second windiness option. The first and second do indeed differ. I tried multiple destinations at distances from 10 to 150 km. It's structural.
                @Con-Hennekens said in In app route/track multiple options/alternatives not working:
                It's structural.
                It seems like you're right. Of the four different options, only the first two are different. Options two, three, and four are always exactly the same as each other! You old sleuth... 😁
                Edwin_M
                Edwin_M
