  4. Update from 4.0.8 244
3 Posts 3 Posters 75 Views 2 Watching
  • RetiredWingMan
    I thought 265 was available so I updated my old phone from 4.0.8 244 but it only updated to 263. Failed with the white screen. Deleted data and went through set-up. Updated from 244 to 266 with no problems. Can't say if the update from 244 to 266 would work properly or not. I did an A to B route on 263. I went slightly off route and the App basically hung doing a recalculate. I waited several minutes and it never recovered. The GPS was following my route. I was in a good coverage area but did not have maps downloaded. Restarted the A - B route and It worked fine.
    On my old S7 phone, recent updates to voice handling allow me to fix the static problem I previously reported. Some voices still result in loud static but I'm able to select a voice that works properly.
      @RetiredWingMan Thanks for sharing! 🙂
      Please note that the beta is running on 4.1.0 (your build number were correct to that was just a minor detail).
      The white screen issue has been completely fixed in the latest version!
      • richtea999
        @RetiredWingMan said in Update from 4.0.8 244:
        I tested that exact update (mainly because it's Production -> latest beta) and it does work fine, with no white screen:
        https://forum.myrouteapp.com/post/40306
