  4. A to B route forgets dirt option
10 Posts 3 Posters 139 Views 3 Watching
  • RetiredWingMan
    I noticed while out yesterday, selected a destination and set my options. Then hit navigate. On the screen with the start button I can check the routing options again. Invariably the allow dirt roads is turned on again! It does not appear to forget other options.
    The screen below shows after selecting the destination.
    This screen shows the dirt roads is set again.
      @Doug-Robinson, I tested just like you showed above, but I do not get that discrepancy. Dirtroads too exactly shows the same status in both windows.
        @Con-Hennekens I don't know what to say other than it is very consistent on my S20. I got caught again last night, ended up on a gravel road after forgetting to disable gravel roads before hitting the start button.
          Interesting. Both code and tests say it works as it should 🙂
          Curious how this could happen.
          So every time you disable dirt roads and go to the next screen, it is enabled again?
            @Doug-Robinson, can you make a screenrecording of this problem in action?
              @Con-Hennekens I emailed a screen recording to Corjan.
                @Corjan-Meijerink I updated MRA on my older Samsung S7. It has the same issue with dirt roads.
                  Thanks for sharing, I'll investigate.
                    @Corjan-Meijerink I just tried this again with ver 263. It appears to retain the options correctly. Cheers.
                      @RetiredWingMan Cool! 🙂
