  4. Additional WP (last version)
11 Posts 3 Posters 143 Views 3 Watching
    Hello, I noticed something today and do not know if this is a Bug or on purpose.
    When you create an A to B route curvy, you can not add waypoints. Or rather, you can add them, it is also confirmed (with the new green bar), but they do not appear on the route.
    I checked this with Android and iOS and the big curvy option. I had only success with the strait route.
    I will check this with the other options.
    Corjan Meijerink Hubert Thoring 2 Replies Last reply
      @Jörgen adding waypoints with track navigation is not possible.
      I guess you long pressed the map and saw the confirmation? Anyhow, it isn’t supported so the confirmation message should not be displayed. Please let me know what you did 🙂
      Jörgen 1 Reply Last reply
      -1
        @Jörgen : Du hast Recht, bei einer direkten Route A zu B kann man nach dem Start einen PoI zB die Tankstelle anklicken = länger drücken dann kommt auch die Anzeige WP einfügen und kann mit ja bestätigt werden.
        Der neue WP wird aber nicht eingebunden , also auch nicht als Ziel mit berücksichtigt.
        Ich hatte es ja zuvor auch nur mit geplanten Routen getestet, und dazu meine Feststellung schon beschrieben.
        VG 👋❗️
          @Corjan-Meijerink said in Additional WP (last version):
          Open App
          click no to continue navigation
          zoom into map
          set target WP
          choose curvy road
          click yellow arrow
          see route
          click start
          click compass long
          see route
          zoom map
          choose another WP
          see add WP
          click confirm
          see WP added to route
          see start point
          click compass long
          see route - but no WP was added
            This post is deleted!
              Here a video to that.
              https://youtu.be/iFZJW4O3lyA
                So yeah, the long press somewhere on the map 😉
                Thanks.
                  Hi, is there the intention to make it possible in A to B navigation to add waypoint?
                    @Jörgen you can already add a search result to the route 🙂
                    In the future we want to add the possibility to add an extra stop to the route. A-B-C so to say.
                      Ok, but "add a search result to the route", works only for a direct A-B route. If you use one of the curvy options, the menu item "add WP" is not available.
                        @Jörgen That's correct.
                        Track navigation works without waypoints and therefore they cannot be added to your route 😉
                        We might look into a complex solution for this but now is not the time.
