  4. Skip waypoints - skip to wanted. nr
4 Posts 3 Posters 63 Views 1 Watching
  • BikeLover
    BikeLover
    BikeLover
    wrote on last edited by BikeLover
    I made a trip with 80 waypoints, battery went dead, so had tot skip about 40 times when I restarted the phone and MRA
    It would be an asset if you could enter a waypoint number to which you want to skip
    • BikeLover BikeLover
      @BikeLover690 once you have entered navigation, you can display the entire route, long press on the waypoint you want to skip to. Easy. You an also display the list of waypoints and long press on the one you want to skip to. Also easy. This assumes your running a current version of MyRoute-app.
      BikeLover 1 Reply Last reply
        BikeLover
        BikeLover
        BikeLover
        @Doug-Robinson awesome, thx for the tip !
          @BikeLover690 said in Skip waypoints - skip to wanted. nr:
          Hahaha just for the sake of all others reading along here. It seems that you did not read the mandatory app introduction for the nav part😋. It mentioned the solution @Doug-Robinson talks about (sort of):
          The last line explains the long press part
          Note though that this is done through the waypoint list but the same behaviour holds true for longpress on points in the map. That part in fact is not mentioned in the intro unfortunately.
          BikeLover
          BikeLover
          • Strange translation
            martin-phogel.de
            martin-phogel.de
            10.5k
          • Undo/Redo tool is hidden
          • Crazy routing
          • Which route is shown?
