  4. Camera warning on screen - unable to go the settings
9 Posts 3 Posters 87 Views 2 Watching
  • MarcM
    MarcM
    MarcM
    Issue on the iPhone:
    When I stop and at that time there is a speed camera in the neigboorhood ("flitser" 200m on the screen), it is impossible to go to the settings menu,(...) (with the iPhone)...
    • MarcM MarcM
      @MarcM, you can disable the speedcam warnings in the settings 😉
      MarcM 1 Reply Last reply
      • StanisÅ‚aw
        I think there should be a possibility to close such announcement manually and go back to the normal navigation screen.
        Regards
        Staszek
        • Con Hennekens
          I think this problem is overrated. Speedcams are always on straights. Drive 250 mtrs and the warning disappears. Red light cams are always on crossings. You should not want to enter the menu on crossings.
          Stanisław MarcM 2 Replies Last reply
            @Con-Hennekens This is not big problem but I can not see a reason to not have a simple button wit a cross to close this popup. There can be a fuel station near the camera or a parking, where I could do some checking in the settings etc.
            Regards
            Staszek
            Con Hennekens MarcM 2 Replies Last reply
            • StanisÅ‚aw StanisÅ‚aw
              @Stanisław, that's a valid argument indeed.
                MarcM
                MarcM
                MarcM
                @Con-Hennekens It’s your personal opinion …
                  MarcM
                  MarcM
                  MarcM
                  @Con-Hennekens Why should I? It’z a joke I think
                    MarcM
                    MarcM
                    MarcM
                    @Stanisław I totally agree with you
                    MarcM
                    MarcM
                    • Strange translation
                      martin-phogel.de
                      martin-phogel.de
                      10.5k
                    • Undo/Redo tool is hidden
                    • Crazy routing
                    • Which route is shown?
