  4. Message "card offline"
8 Posts 4 Posters 85 Views
  • Calibos
    Calibos
    Calibos
    wrote on last edited by Calibos
    even with an available network connection, when the "offline navigation" parameter is selected in the functional menu, by selecting "offline map" MRA displays the message to go online ?
    I don't quite understand what that means, The message is a contradiction
    • Calibos Calibos
      @Calibos while offline navigation is enabled the entire navigation module is restricted from any internet connection.
      Offline maps require internet for any interaction and therefore cannot be viewed while offline mode is enabled πŸ™‚
      RetiredWingMan Calibos 2 Replies Last reply
        @Corjan-Meijerink please review your answer. Is it correct?
          Calibos
          Calibos
          Calibos
          I'm ok with this but then the message in French should be "offline maps cannot be downloaded or updated with the offline option selected"
          And the behavior of the route module should then also not allow access to online routes but only to the download folder
          • Calibos Calibos
            @Calibos, Offline maps and Offline navigation are two separate things. The use of offline maps does not implicate there is no internet access for others things then maps (trafic info and address lookup for example). Also The Main screen of the app is not the navigation module. Browsing the online folders happens when the navigation module has not been started yet.
            Calibos 1 Reply Last reply
              Calibos
              Calibos
              Calibos
              In fact my sugestion only referred to the displayed message "Offline maps cannot be used when the application is configured to be offline".
              I don't know if it's a translation problem but in French it's like saying "you can only use offline maps if you're online" it's a bit
              of a misinterpretation.
              But in the end when we found the solution it's a detail.
              • Calibos Calibos
                @Calibos ah thanks! Yeah, I’ll edit the translation πŸ™‚
                It’s more like you cannot manage offline maps when offline mode is enabled
                • Calibos Calibos
                  @Calibos, yes, good point.
                  Calibos
                  Calibos
                  • Help please, new user
                    Bull Tahr
                    Bull Tahr
                  • My Routeapp Stays questions
                  • MRA 6.0.0 (515) Live Tracking - What exactly is shared?
