  4. Some problems/questions from todays ride:
4 Posts 2 Posters 83 Views
  • Angelo Greco
    Angelo Greco
    Angelo Greco
    This time I am using the correct version of the software 😏
    I have previosly created a couple of routes and downloaded them to the app on my Huawei Psmart.
    1. I selected the rout: Open Route: Navigate: Start:
      As soon as I started navigating I had to take a detour due to roadworks and the app recalculated the route.
      The route is only 68 miles, not complicated, but it took a long time to recalculate, when finished I had completely lost my original rout and a totally different route to the same location had been selected.
      When a recalculation is triggered does the app recalculate the route to the next way point then resume as previously planned? If so, then my rout was created with only 2 way points (start and end) so this would explain why this happened. So in future, if a create a route with many way points re routing will not lose the whole route. Am I correct?
    2. Continuing on the new route the lagging issue was very much evident and negotiating close junctions was difficult. I think (from another thread) that this is now resolved is this correct?
    3. Route recalculations were being triggered almost at every major junction, even though I was staying on track. Is this due to the lagging issue?
    4. Route recalculation was taking a long time 10 to 15 seconds, is this acceptable?
    5. Does the map location search only work online? Should it work Offline?
    Thank you.
    • Angelo Greco Angelo Greco
      Thank you.
      @Angelo-Greco,
      1. Yes it navigates quickest way (or whatever your setting is) to the next waypoint. If you have only two waypoints no route whatsoever can be guaranteed.
      2. Will be solved first update
      3. No idea, have not seen that at all
      4. Where you navigating online or offline? I see your phone is somewhat of a budget phone (no offense). I can imagine that online navigation is quicker due to the calculation power of the hosting servers. A phone is no match for that. It would be nice to know if you experience different results when navigating on-line.
      5. yes, indeed it does only work online. Maybe something for a later date.
      Angelo Greco 1 Reply Last reply
        @Angelo-Greco,
        Angelo Greco
        Angelo Greco
        Angelo Greco
        @Con-Hennekens :
        1. I don't know if at the time I was online or ofline as I don't know the status of the signal at that time?
          Agree my phon is not top end, however, other navigation apps appear to work faster than MRA?
          @Con-Hennekens :
          @Angelo-Greco, I can imagine, but maybe you could try some calculations online and offline to give my hunch a reality check 😉
          Angelo Greco
          Angelo Greco
