  4. Routing Preferences Not Preserved
4 Posts 3 Posters 37 Views
  • Angelo Greco
    Angelo Greco
    Angelo Greco
    MRA does not appear to remembeer my route preferences and I have to select them every time I set up a route.
    Also, Once a route has been calculated with correct preferences and navigation is underway, if I deviate from the route, when MRA recalculates, again it does not apply the rout preferences that were chosen at the begining of the route.
    Example, selected a route avoiding highways (which I always do on motorcycle), I had to take a diversion from the route, when MRA recalculated it tried to route me on to the motorway that was close by.
    • Angelo Greco Angelo Greco
      @Angelo-Greco the routeplanner indeed won’t save the preferences. Within the app, we only persist the A-B routing settings for the fastest route (avoid highway, toll & ferries).
      I believe the settings are used correctly on recalculation but I’ll check that 🙂
      Angelo Greco 1 Reply Last reply
        Angelo Greco
        Angelo Greco
        Angelo Greco
        @Corjan-Meijerink , So every time I open the app I will need to set my navigation preferences?
          @Angelo-Greco, no, not if you stick with fastest route (the straight line choice in the navigation app). Just tested that.
          Angelo Greco
          Angelo Greco
