  4. Roundtour settings menu disappears
4 Posts 3 Posters 64 Views
    A small bug my wife actually came up with 😉
    If you start a roundtour, you get a map overview with the route projection, and a flouting menu that you can enlarge to access "allowed roads", like this:
    Now if you swipe down you close the menu without any means available to open it again. All that can be done is go back and start over.
    • Jan-Willem Verloop
      Jan-Willem Verloop
      Jan-Willem Verloop
      wrote on last edited by Jan-Willem Verloop
      I noticed the same problem this afternoon!
        @Con-Hennekens correct! Something that was by design but is already on our list of minor things we need to improve because of bad design 😉
          You can look forward to the upcoming update 😏 @Con-Hennekens
          Jan-Willem Verloop
          Jan-Willem Verloop
